RAM for MCS7835 with same part number does not work why?
dwayne rattan
The RAM that came with the server are the same.That the part numbers match. however there is a difference with these numbers 1RX8 pc2-5300F-555-12-A1 and 1RX8 pc2-5300F-555-11-A0 does this matter. Both the old and the new RAm are from the same manufacturer. The original RAM  works well but when I put the new RAM the correct sequence the server does not boot.
Any help will be appreciated thank you.
dwayne rattan
I found the problem a while back after thinking I spec the wrong RAM. It turned out it was correct just one out of the two was defective.
Hey Dwayne,
Great to know this.
Incase you perform some upgrade later.
Please make sure of following gotcha's.
For the complete  Trobleshooting guide, you can find here :
http://www.cisco.com/en/US/docs/unified_computing/ucs/ts/guide/UCSTroubleshooting.pdf
