Routing issue with CSS 11503
secretariat
Community Member
The senerio contains a PIX 515 E firewall,4507R Chassis switch and a CSS 11503. The servers in inside zone of the PIX is load balanced using a vip with default route specified in the CSS is the inside zone interface IP of the PIX
Now I would like to load balance the servers in the DMZ zone of the PIX with a separate vip(from DMZ zone) in the same CSS. Since the default route in CSS is towards the inside zone of the PIX, I am unable to see the load blanced pages from dmz. Is there any solution to load balance the servers of the 2 zones with 2 different vip's using a single css ?
jsivulka
Level 10
Level 10
The default behavior is to use the calling device's CSS for the redirected calls. In your case it sounds like you want to use the redirecting device's CSS. I haven't tried this myself but I believe you will need to change the following registry entry on your PGs. You will want to use option 2 (ROUTEADDRESS_SEARCH_SPACE).
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco
Systems,Inc.\ICM\IPCCL\PG1B\PG\CurrentVersion\JGWS\jgw1\JGWData\Dynamic
"UseRouteAddressSearchSpace"=dword:00000000
- Used to control behavior on CTI Route Points for Route Selects.
UseRouteAddressSearchSpace can be to set 0, 1, or 2 where :
DEFAULT_SEARCH_SPACE = 0
CALLINGADDRESS_SEARCH_SPACE = 1
ROUTEADDRESS_SEARCH_SPACE = 2
