Using 24 ports on 5548 for non fabric devices with 24 FEX's attached.
curtis.brown
If you have 24 Nexus 2248 fabric extenders dual-homed to two Nexus 5548 switches using one 10Gig port from each 2248, can the remaining 24 ports on each 5548 be used for non fabric devices? (Ex. Blade server chassis with integrated switches)
Reza Sharifi
Yes, you can use the remaining 24 ports for whatever you want to connect.  It could connect to IBM chassis, other routers, switches, etc...
