VxLAN Gateway products
andrea.dupuy
I have a simply question, because this point is not necessarely clear in datasheets.
Can I install a VxLAN Gateway with the virtual switch Cisco Nexus 1000 V or this option is only available on the Cisco Nexus 1010 or 1100?
The goal of this question is I want connect two different datacenters between them. I think I must use the VxLAN Gateway for doing that right?
Thank you for future answers.
Andrea
Ruben Cocheno
VxLAN is supported in Nexus 1k, this link explain how to integrate with Vmware.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-1000v-switch-vmware-vsphere/guide_c07-702975.html
You have other technologies to interconnect DCs, there are some cons/pros , choose the best to fit your design/purpose
http://www.cisco.com/c/en/us/solutions/data-center-virtualization/data-center-interconnect/index.html
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Just FYI
VMware, Microsoft end encapsulation protocol turf war with GENEVE
Microsoft and VMware have proposed the GENEVE encapsulation protocol to the IETF. It would standardize tunneling methods for network overlay software.
http://searchsdn.techtarget.com/news/2240219051/VMware-Microsoft-end-encapsulation-protocol-turf-war-with-GENEVE
