on 01-20-2012 10:47 AM
In this document I'll discuss the operation, use and some examples on RPL, or the route policy language.
Route policies are mandatory for E-BGP peers, at least a "pass-all" like RPL is required in order to import and export routes.
In IOS we used to have route-maps to control the import, export and manipulation of routes. IOS-XR doesn't have route-maps but something more powerful called route policy language. It is a very programmatic approach in route-maps.
Where as IOS route-maps operate as a series of statements which are executed sequentially, Route-policies not only operate sequentially but provide the ability to invoke other route-policies much like a ‘C’-program is able to call separately defined functions. This enables to creation of hierarchical policies. In addition, and most importantly into respect the scope of this paper, route-policies are ‘compiled’ into a run-time executable portion of code.
When you have configured a route policy that you want to edit afterwards, you need to restart from scratch or copy paste the existing RPL as entering the route-policy configuration would wipe the existing one out:
RP/0/RSP0/CPU0:A9K-BNG(config)#route-policy test
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if med eq 100 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set local-preference 100
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#endif
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#end-policy
RP/0/RSP0/CPU0:A9K-BNG(config)#commit
Fri Jan 20 14:58:39.900 EDT
% WARNING: Policy object route-policy test' exists! Reconfiguring it via CLI wil
l replace current definition. Use 'abort to cancel.
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if local-preference eq 123 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set origin incomplete
RP/0/RSP0/CPU0:A9K-BNG(config)#do sh run route-policy test
Fri Jan 20 14:59:53.705 EDT
route-policy test
endif
end-policy
As you can see the previous if statement is completely gone, copy pasting and offline editing are also not very easy to use! There is a solution!
RP/0/RSP0/CPU0:A9K-BNG#edit route-policy test ?
emacs to use Emacs editor
nano to use nano editor
vim to use Vim editor
<cr>
I tend to prefer VI and then you can edit your RPL in a VI like manner:
Editting screen:
route-policy test
else if med eq 100 then
set weight 44
endif
end-policy
I am inserting the bold italic lines and press "ZZ" to exit and save the VI editor. (Note I made a config error in RED)
"/dev/shmem/rpl_edit.115790135" 8 lines, 149 characters written
Proceed with commit (yes/no/cancel)? [cancel]:
Now the config error here by splitting "else if" and look what happens when I try to commit:
Parsing.
149 bytes parsed in 1 sec (148)bytes/sec
% Syntax/Authorization errors in one or more commands.!! SYNTAX/AUTHORIZATION ER
RORS: This configuration failed due to
!! one or more of the following reasons:
!! - the entered commands do not exist,
!! - the entered commands have errors in their syntax,
!! - the software packages containing the commands are not active,
!! - the current user is not a member of a task-group that has
!! permissions to use the commands.
set weight 44
endif
end-policy
Continue editing? [no]:yes
"/dev/shmem/rpl_edit.115790135" 8 lines, 145 characters written
Proceed with commit (yes/no/cancel)? [cancel]: yes
Parsing.
145 bytes parsed in 1 sec (144)bytes/sec
Committing.
Prepared commit in 0 sec
1 items committed in 1 sec (0)items/sec
Updating.RP/0/RSP0/CPU0:Jan 20 15:04:20.101 : config[65848]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'root'. Use 'show configuration commit changes 1000000522' to view the changes.
Updated Commit database in 1 sec
So from now one when you want to edit RPL's, prefix sets or as-sets or community sets, use this editor
RP/0/RSP0/CPU0:A9K-BNG#edit ?
as-path-set edit an as-path-set
community-set edit a community-set
extcommunity-set edit an extended-community-set
policy-global edit policy-global definitions
prefix-set edit a prefix-set
rd-set edit a rd-set
route-policy edit a route-policy
The route policy requires a "ticket" for the route to be accepted or dropped. These are the different operatators
pass grants a ticket to defeat default drop
Execution continues after pass
Any set at any level grants a ticket
Execution continues after set
Values can be set more than once
• Drop – prefix is discarded
Explicit drop stops policy execution
Implicit drop (if policy runs to end without getting a ticket)
One thing important to add is here that if you have a policy that is "sequential" like
if med 10 then
set med 20
endif
if med 20 then
drop
endif
the execution will NOT drop prefixes with MED10. The reason for that is, although somewhat counter intuitive, that the sequence of operation uses the ORIGINAL value during processing, hence the second if statement will not match for the what was original med of 10...
If you like to get the behavior that both 10 and 20 are dropped, you could do something like this:
if med 10 then drop
else if med 20 then drop
else pass
endif
Don't forget the final pass, as there is an implicit deny.
The ability to reference one policy in another
route-policy one
set weight 100
end-policy
route-policy two
set med 200
end-policy
route-policy three
apply two
set community (2:666) additive
end-policy
route-policy four
apply one
apply three
pass
end-policy
The ability to call one policy with a variable to be used in another policy:
route-policy one ($med)
set med $med
end-policy
route-policy two
apply one (10)
end-policy
Or with 2 variables:
route-policy three ($med,$origin)
set med $med
set origin $origin
end-policy
route-policy four
apply three (10, incomplete)
end-policy
In your RPL you can put the prefix set or as-path etc in the IF statement construction or you can reference a separate set with the AS-list.
They look like the following:
Inline:
route-policy use_inline
if as-path in (ios-regex '_42$', ios-regex '_127$') then
pass
else
drop
endif
end-policy
Named-Set:
as-path-set named_set
ios-regex '_42$',
ios-regex '_127$'
end-set
route-policy use_named
if as-path in named_set then
pass
else
drop
endif
end-policy
There is a performance difference between teh two. the Named Set is obviously slightly slower, but is easier to manage especially when the list gets long. I would personally recommend for short lists to use inline and for longer lists to use the named-set.
Each individual set element results in a separate call to the expression engine:
as-path-set as_51
ios-regex ‘_2129$’,
ios-regex ‘_2147$’,
ios-regex ‘_2856$’,
ios-regex ‘_3486$’,
ios-regex ‘_6432$’,
ios-regex ‘_6468$’,
ios-regex ‘_7310$’,
ios-regex ‘_7768$’,
ios-regex ‘_7862$’,
ios-regex ‘_8296$’
end-set
The same set can be written as follows:
as-path-set as_51
ios-regex '_(2129|2147|2856|3486|6432|6468|7310|7768|7862|8296)$'
end-set
as-path-set aset1
ios-regex ’_42$’,
ios-regex ’_127$’
end-set
prefix-set galaga
171.68.118.0/24,
192.168.0.0/16 ge 16 le 30
end-set
community-set cset1
12:34,
12:78,
internet
end-set
internet
local-AS
no-advertise
no-export
private-as
show bgp policy route-policy <name>
Only display prefixes matching policy – filter show command
RP/0/0/CPU0:XR#show rpl route-policy states
ACTIVE -- Referenced by at least one policy which is attached
INACTIVE -- Only referenced by policies which are not attached
UNUSED -- Not attached (directly or indirectly) and not referenced
Here some examples of using prefix-sets. The use of the variable masks is not easy to understand and I found the CCO documentation not very explanatory, so here a few extra words on that.
Prefix: Explanation:
10.0.1.1, match only one possible value, 10.0.1.1/32, mask omitted means 32.
10.0.2.0/24, match only one possible value, 10.0.2.0/24
10.0.3.0/24 ge 28, match a range of prefix values, from 10.0.3.0/28 to 10.0.3.255/32
10.0.4.0/24 le 28, match a range of values, from 10.0.4.0 to 10.0.4.240 (eg we can’t “reach” the last 4 bits)
10.0.5.0/24 ge 26 le 30, matches prefixes in the range from 10.0.5.0/26 to 10.0.5.252/30
10.0.6.0/24 eq 28 match any prefix of length 28 in the range from 10.0.6.0/28 through 10.0.6.240/28
10.0.7.2/32 ge 16 le 24, matches any prefix of length 32 in the range 10.0.[0..255].2/32 (from 10.0.0.2/32 to 10.0.255.2). This is a little funky given the “7” in the 3rd octet which effectively becomes don’t care.
10.0.8.0/26 ge 8 le 16 matches any prefix of length 26 in the range 10.[0..255].8.0/26 (from 10.0.8.0/26 to 10.255.8.0/26)
I am using an RPL that sets the local pref to 1234 if it matches the prefix set, and that prefix set is as per the above sample list.
=> What is excluded here ? Is 10.0.3.128 excluded from the prefix range ?
Whether the .128 is excluded or not, depends on the mask of the prefix being advertised.
Basically what this means is that if the mask of the route is larger or equal than 28 (so 29,30,31,32) then it matches:
Network Next Hop Metric LocPrf Weight Path
*>i10.0.3.0/28 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.3.16/28 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.3.32/28 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.3.48/28 8.1.1.1 100 1234 0 2 i
*>i10.0.3.0/26 8.1.1.1 100 300 0 2 3 {4} i
*>i10.0.3.64/26 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.3.2/31 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.3.4/31 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.3.6/31 8.1.1.1 100 1234 0 2 i
*>i10.0.3.0/24 8.1.1.1 100 300 0 2 3 {4} i
=> What is excluded here ? 10.0.4.1, .2, .3, .17, .18,.19,.20, etc?
Same as before, but now where the mask is less than 28, so routes in the 10.0.4.x range that have a mask that is shorter 28 will get “hit”.
The mask on the prefix itself sets the “base”. Eg 10.0.3 would not match here as it is not part of the 10.0.4.0/24. Seems obvious but just to be clear ...
*>i10.0.4.0/24 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.4.0/26 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.4.64/26 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.4.128/26 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.4.48/28 8.1.1.1 100 1234 0 2 i
*>i10.0.4.64/28 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.4.24/30 8.1.1.1 100 300 0 2 3 i
*>i10.0.4.28/30 8.1.1.1 100 300 0 2 {3} i
Combining the previous two together on the .5.0 range:
*>i10.0.5.4/30 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.5.8/30 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.5.12/30 8.1.1.1 100 1234 0 2 i
*>i10.0.5.4/31 8.1.1.1 100 300 0 2 3 {4,5} i
*>i10.0.5.6/31 8.1.1.1 100 300 0 2 i
*>i10.0.5.5/32 8.1.1.1 100 300 0 2 3 {4,5,6} i
*>i10.0.5.6/32 8.1.1.1 100 300 0 2 3 i
*>i10.0.5.0/25 8.1.1.1 100 300 0 2 3 {4} i
*>i10.0.5.128/25 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.5.64/26 8.1.1.1 100 1234 0 2 {3,4} i
*>i10.0.5.128/26 8.1.1.1 100 1234 0 2 3 {4,5} i
*>i10.0.7.2/32 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.7.3/32 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.0.2/32 8.1.1.1 100 1234 0 2 3 {4} i
*>i10.0.0.3/32 8.1.1.1 100 300 0 2 {3,4} i
*>i10.1.7.2/32 8.1.1.1 100 300 0 2 3 {4} I <<doesn’t match because of 2nd octet
If I slightly change the prefix statement to: 10.0.7.4/32 ge 16 le 24
*>i10.0.7.0/30 8.1.1.1 100 300 0 2 3 {4} i
*>i10.0.7.4/30 8.1.1.1 100 300 0 2 {3,4} i
*>i10.0.7.8/30 8.1.1.1 100 300 0 2 3 {4,5} i
Still no match as the base mask is not met on the prefixes received.
So the /<whatever> determines the MASK of the route I wanted to match. whereas the GE/LE provide me the variance in either that mask (if bigger) or from the other octects (if smaller then the /mask)
To determine what in your route-policy is consuming the majority of the time, you can use route profiling.
It allows some data collection in the background with minimal impact on the execution of the rpl. After the collection has been running for some time you can use show commands to find out which steps take a lot of time in the execution and make some improvements.
Once we figure out which portion of the policy is performance drag, its much easier to try out an alternative. Something like regex match always failing means we need to evaluate route using prefix match prior to validating its as-paths.
Example usage:
debug pcl profile detail
then
Policy execution profile
Protocol : bgp 10
Attachpoint : neighbor-in-dflt
AP Instance : default-IPv4-Uni-1.2.3.4
Policy Name : rpl_profile(nexthop)
Pass : 10
Drop : 5
Total : 15
Avg execution time : 110usec
Router#sh rpl route-policy rpl_profile detail
route-policy test
apply test2
done
end-policy
route-policy test2
end-policy
route-policy rpl_profile($p_nexthop)
set med 155
else
set med 77
endif
apply test
end-policy
Protocol : bgp 10
Policy : rpl_profile(nexthop)
Pass : 15
Drop : 0
Total : 15
GOTO : PXL_0_6
Router#
As you have noticed when editting RPL's you need to reconfigure the complete policy in the regular CLI. An easier method is using the "edit" option described above.
When you are changing your RPL or prefix-set or any other list that RPL is using, it will trigger a few things:
If the RPL is used for BGP and your peer is not REFRESH capable, it will restart your BGP session.
If the peer is REFRESH capable a full table refresh is executed.
The reason for that is, that the RPL change or say prefix set change could have excluded some routes before that now may need to be imported.
On the Receiving Side:
For BGP, routes that are filtered are completely discarded and are NOT kept in memory with some kind of mark that says bgp rpl filtered.
We will use route refresh to obtain the routes again from the neighbor whenever there is a change in inbound route policy.
For this the neighbor has to be refresh capable, else we have to do clear bgp.
When the BGP peer receives a route refresh request it sends the complete table again to the requesting peer. While asking for the table they ask for the relevant (AFI, SAFI) table. When the routes are received from the peer an inbound filter if any is applied and the routes are aggregated.
On the sending side:
if I apply an RPL basically removing some previously advertised route, would BGP send withdraws for these now filtered routes?
What would rpl/bgp do when the RPL is modified to:
1) do advertise some previously filtered routes
To advertise previously filtered routes it is similar to regular advertising of routes
2) stop advertising previously advertised routes
BGP will send withdraws when it stops advertising previously filtered routes.
Xander Thuijs, CCIE #6775
Sr. Tech Lead ASR9000
"path-type is ibgp" is different to "as-path is-local". An ibgp path may have been learnt from another ebgp neighbor at the opposite end of your AS. is-local means strictly locally originated in your own AS.
I will stick with "as-path
Hi Xander,
I have one policy on Junos for route leaking and I am trying to figure out the best way to migrate it on IOS-XR.
On
They are leaking directly connected routes and routes with specific as-path.
term connected {
from {
instance master;
protocol direct;
then accept;
term local-customers {
from {
instance master;
as-path path-local-customers;
then accept;
term deny-all-other {
then reject;
I want to achieve the same on IOS-XR. Is MP-BGP the only option?
Here is a simple drawing. I think that I know how RPL should look like, but I would like to know your suggestion how to get the same result like it's on Juniper.
To leak static routes from one VRF to another, do these steps:
If you have CE neighbors in the source VRF, then delete the community at the neighbor out route-policy.
vrf v1
address-family ipv4 unicast
export route-policy export-static
vrf v2
import route-target
1:1
route-policy redis-static
set community (0:100)
end-policy
if community matches-any (0:100) then
set extcommunity rt (1:1)
endif
delete community in (0:100)
end-policy
router static
vrf v1
3.1.1.1/32 Null0
router bgp 3
address-family vpnv4 unicast
vrf v1
rd 1:1
redistribute static route-policy redis-static
vrf v2
rd 1:3
Hi Jakob,
somehow I got an e-mail notification for your reply but it's missing here.
Good thing is that I got your post on e-mail.
I helped me a lot with the example but I am stuck with conditional export.
On
VRF "TEST_INTERNET" is the main VRF with
I want to export def. route, directly connected routes and
I did some testing and found out that with this route-policy I will not export BGP learned routes to all other PE's with RT 65000:101 because the router will not set RT 65000:101 for BGP routes, only for static and directly connected routes.
vrf TEST_INTERNET
import route-target
65000:101
65000:666
export route-policy TEST_INTERNET_EXPORT
if community matches-any (123:123) then
set
endif
delete community in (123:123)
end-policy
I have tried with "else" but it was not working at all.
Can you help me out?
I have managed to do leak the routes between the VRF's other PE's got the BGP routes as well.
There is one issue though.
In VRF "TEST_INTERNET" I have a static def. route pointing to Null 0 and vrf "TEST_ARBOR" got this route but I think that because the next hop interface in null 0 it's useless for reaching unknown prefixes. It's not possible to leak the whole routing table.
show cef vrf TEST_4ARBOR 120.1.1.1
Fri May 26 12:16:28.531 UTC
0.0.0.0/0, version 22, attached, proxy default, null0 adjacency, internal 0x5000051 0x0 (ptr 0xa13d92f4) [1], 0x0 (0xa13a3e18), 0x0 (0x0)
Updated May 26 12:11:56.850
Prefix Len 0, traffic index 0, precedence n/a, priority 3
via Null0, 13 dependencies, weight 0, class 0 [flags 0x6008]
path-idx 0 NHID 0x0 [0xa0d1f050 0x0]
next hop VRF - 'TEST_INTERNET', table - 0xe0000012
null0 adjacency
Is there a solution for this?
EDIT:
I had to point the def.
At the end "as-path
To get this to work I have set community X inbound from this BGP peer and I have used this community to match the prefix. If
I think that the execution time is important, like you have wrote under "Verifying performance of your RPL", right?
there is no limit to the number of if/then/else constructs or size of an rpl or size of a prefix set.
the good thing is the execution is really in the number of usecs per prefix, especially when using faster processors. so it shouldnt be a worry.
you can measure the time of execution with the method below, and if you multiply that by the number of prefixes you can derive what time it would take from a full loading concept, but yeah RPL may only add a second total or so on the some minutes of loading and programming a full table.
xander
Anyone any guess what would mean/match this prefix-set?
prefix-set TEST-TONY-PS
10.0.0.0/24 ge 16 le 25
end-set
My XR accepted that syntax. I know from the post that when you put the "ge-le" range being less than mask it specify "dont care" bits as is here:
However here I extened the "ge-le" being more than the mask itself. So from my example will that (ge 16 le 25) being all "dont care bits" but mask has to be /24 which eventually makes my statement (ge-le being more than mask) irrelevant?
Thanks a lot for any answer
hi anton, that is fine, you can do that, you effectively define a base mask and what can change under that base mask.
so you effectively have a combination of these 2 behaviors:
so you allow prefixes now with the 3 octet changing, and the 4th having a range between 24 and 25 mask
cheers!
xander
Hi Xander,
thanks a lot for your quick reply. I meantime tested the behavior and its exactly how you said. If someone is interested here are the testing results:
router static
vrf Test
30.0.7.128/25 GigabitEthernet0/0/0/0 10.0.0.2 ---> redistributed to BGP
RP/0/0/CPU0:AUTOMATION-TESTING#show rpl route-policy TEST-RP detail
Fri Jul 21 09:40:26.139 UTC
prefix-set Test
30.0.7.0/24 ge 16 le 25
end-set
if destination in Test then
set extcommunity rt (24714:6666) additive
endif
end-policy
RP/0/0/CPU0:AUTOMATION-TESTING#show bgp vrf Test 30.0.7.128
Fri Jul 21 09:36:05.777 UTC
BGP routing table entry for 30.0.7.128/25, Route Distinguisher: 10.0.0.1:0
Versions:
Process bRIB/RIB SendTblVer
Speaker 28 28
Local Label: 24004
Last Modified: Jul 21 09:34:11.423 for 00:01:54
Paths: (1 available, best #1)
Not advertised to any peer
Path #1: Received by speaker 0
Local
10.0.0.2 from 0.0.0.0 (10.0.0.1)
Origin incomplete, metric 0, localpref 100, weight 32768, valid, redistributed, best, group-best, import-candidate
Received Path ID 0, Local Path ID 0, version 28
Extended community: RT:24714:6666 RT:24714:10000
very cool!! and thanks also for sharing your test result! visuals always help right! :)
cheers!!
xander
Hi there. Its me again :D I have observed that I can construct prefix-set like the one following:
prefix-set Test
10.0.4.18/24 eq 28,
10.0.4.32/24 eq 28
end-set
I know that 10.0.4.18 is not quite relevant as we cannot have network 10.0.4.18 with mask /28 however IOSXR allowed me to put syntax like that so lets take this as an example.
Now the issue is when I have prefix set like the one above it doesnt match my static route 10.0.4.32/28 redistributed to BGP. If I remove from the prefix-set 10.0.4.18/24 eq 28 and keep just the 10.0.4.32/24 eq 28, then I have a match for my route. Is there some reasonable explanation for that behaviour?
Attaching the output, which might be more descriptive. The device is XRv 6.1.2
Thanks a lot
hmm that is interesting indeed. the prefix set should operate in an OR fashion soif the first one doesnt match the second one needs to be evaluated.
I can see the first one being a sort of errored out case, and it is case that there is no or little validation on those sets to behonest so it relies on user intelligence a bit more I'd say, but still if the first one errors our, the 2nd should also (because of the inconsistent mask).
note that with the /<mask> eq <bits> the mask here merely defines which pieces of the prefix are static and the bits define the actual mask of prefix to be matched.
you could do the debug pcl and see/verify the processing as to how rpl comes to its decision.
it is obviously a config situation, but indeed we can check to see what the precise reasoning for this is.
xander
