All ,
I have requirement , would be great if you can share your experience and knowledge
Requirement 1
1 x Cisco ASR 1004 40Gig
4 x SPA-10X1GE-V2 (10 port Ethernet Module)
Requirement 2
3 x SPA-10X1GE-V2 (10 port Ethernet Module)
1 x SPA-8XCHT1/E1-V2 (8 Port Channelized T1/E1 Module)
When Tried to build the Bill of material in cisco CCW tool , finding an error while adding double height SPAs (SPA-10X1GE-V2 ) , the below combination used.
Added two ASR1000-SIP40 .sip40-NB1 , and excluded the SIP slot bundle ASR1000-SIP40-NB0 which supports only 1 *10G SPA adapter
- ASR1000-SIP40 - 2* SPA-10X1GE-V2 ( double height SPAs)
- ASR1000-SIP40-NB1 - 2 * SPA-10X1GE-V2 ( double height SPAs)
Tried to include the SIP slot bundle ASR1000-SIP40-NB0 , along with two ASR1000-SIP40 ,SIP40-NB1 , the configuration not completing and generates error. ( error attached )
- Would like to check with you , the above customer proposed requirement can be done , please suggest
- Also cisco data sheet says , ASR1004 can add 8 SPA , could you please suggest what are the combination can be used ?.
