Cannot get Port Forwarding to Work on ASA 5506
TyraMara
I have an older model ASA 5506 that I'm trying to get port forwarding working on.
I'm connecting to the 5506 via ASDM 7.10, which I know is a bit old, but that's what we have, at the moment.
In Under Firewall > Access Rules > Outside I have the following setup, line 17 is the one that I'm trying to get working but cannot.  What am I missing?  Note that I am hitting the "apply" button after I put the rule in.  The fact that there are zero "hits" tells me that the firewall isn't allowing this rule for some reason.
8 Replies 8
do packet-tracer using same source and destination and see if it hit any ACL before this ACL.
balaji.bandi
what ASA  code running, some old versions of ASA the hit count not stable as new versions, so I will be not replied on that hit counts,
I will open a Real-time Monitor and test it - is that request coming in. Make sure you have any NAT involved, port forwarding, and  ACL in place to allow the required destination.
some example :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/118996-config-asa-00.html
https://www.petenetlive.com/KB/Article/0000077
BB
TyraMara
I'm new to this system, so I may not know what to look for.
@MHM Cisco World ,
I've never worked with Packet Tracer before.  Looking at this tool, it seems to identify how a packet will travel given an established criteria.
So this is what I did for my test:
  • I turned on this rule:
Then I started an instance of Packet Tracer and ran it as noted.,  The IP address here is the TS server.
So, here we have a failure, it can't get to that port for some reason.
Changing the source to be my remote home office and keeping the destination as the location for the TS server, I get the following results:
Looking at the NAT rules after clicking on the link, the 7th rule was highlighted.
I'm not sure what it is about that rule that would cause a denial here.
TyraMara
@MHM Cisco World , I don't think I understand what you're saying.  If I'm reading you correctly, the packet tracer didn't work correctly because I didn't configure the ports correctly?  I don't think I'm correct, but I'm not sure what else to think here.
Would you clarify for me, please?
from packet-tracer rpf-check make packet drop, what is rpf-check?
it check the NAT of packet inbound with NAT of packet Outbound.
so are you config static PAT for this server ?
@MHM Cisco World ,
OK, I think I understand a little bit better.  Basically, I've configured the inbound leg so that traffic from any IP on port 3389 should hit my TS server, but I don't have that set up on the outbound leg?
Regarding static PAT,
I have a section in the router's UI called "Public Servers."  The TS server is not defined here.  So what I just now did is that I added this server in Firewall > Public Servers.  I set this as follows.  Note that if I click "Specify Public Service if different from Private Service.  This will enable the static PAT, I CANNOT add RDP as the public service.
I cannot add a public server because the IP address that we need to use for RDP is the same as the public interface address.  The UI balks at me when I try to do this:
Not sure if this is relevant right off, but I see in Firewall > Objects > Service Objects/Groups that there are a couple of objects that might be relevant to our situation:
So, I think the answer to your question is no.  I do not have static PAT for this server, and the UI won't allow me to set this up.
