08-29-2013 12:56 PM
Hello all.
We have a 1941 configured like this:
Interface LAN: 192.168.0.1 /24
Interface WAN: 110.109.108.144 /29
We have several NATs working too. I.E: 110.109.108.146:80 --> 192.168.0.5:80
Everything works normally if I try to connect to 110.109.108.146:80 from outside my LAN network, but the problem comes when I try to connect to 110.109.108.146:80 from inside my LAN.
Is there any way to enable connections from my LAN to the WAN interface public address?
TIA
Cheers.
08-29-2013 01:16 PM
Hi Hector,
May be your NAT is not working so that the translation is not working correctly. Try to check the issue with "debug ip nat translation" command to check whether the translation is working correctly.
Can you please provide the NAT configuration?
Thank you.
08-29-2013 01:37 PM
Hi Tania, ty for answering. This is my nat conf:
Interface LAN
ip nat inside
Interface WAN
ip nat outside
ip nat inside source route-map ISP-2 interface WAN overload
access-list 7 permit 192.168.0.0 0.0.0.255
route-map ISP-2 permit 5
match ip address 7
match interface WAN
And we have several nat rules. Here are some:
ip nat inside source static tcp 192.168.0.122 80 110.109.108.146 80 extendable
ip nat inside source static tcp 192.168.0.127 81 110.109.108.146 81 extendable
ip nat inside source static tcp 192.168.0.132 8080 110.109.108.146 8080 extendable
ip nat inside source static tcp 192.168.0.199 50 110.109.108.147 50 extendable
ip nat inside source static tcp 192.168.0.132 80 110.109.108.147 80 extendable
The issue is when we try to acces our tomcat server (192.168.0.132) from our lan using its public IP (110.109.108.146)
Cheers.
