03-30-2017 02:58 AM
I going to buy a Cisco RV320 and need information to change VPI, VCI and Encapsulation.
Can I change this by web GUI or command line?
My Internet service provider (ISP) tell me that I have to change :
PPoE with user and password
VPI
VCP
Encapsulation LLC/SNAP
Kind Regards.
03-30-2017 03:02 AM
Hi!
Maybe this emulator of an RV320 can give you some insights in what you can or cannot do with your the router you would like to buy:
https://www.cisco.com/assets/sol/sb/RV320_Emulators/RV320_Emulator_v1.1.0.09/default.htm
Have fun & Good luck!
04-04-2017 07:34 AM
Thanks bernard but this not is my solution.
I called to cisco support and they tell me that the router dont support VCI VCP and Encapsulation.
I'm going to give it back.
