02-13-2015 08:35 AM
I use Shrew soft vpn client to connect to RV042 in Client access gateway. I'm using PSK for authentication which works great. But I found that there are Client certificate File/Server certificate File cases in Shrew soft authentification part. So its possible to use certificate if I'm right.
On the RV042 side, for Client access gateway (group) mode, I cannot find out this option. What I see is certificates only used for QuickVPN mode.
My question is: Is it possible to configure RV042 in Client access gateway mode and mount the vpn tunnel by using Shrew soft with client certificate file? If yes, how?
Thanks for your answer.
hdam
02-17-2015 08:09 AM
Hi hdam
please follow instructions mentioned here. There is good description how to configure it. Basically firstly generate new certificate, and follow with "Export to Client" button. You will get certificate which you import into ShrewSoft VPN.
michal
02-18-2015 12:08 PM
Hi michal,
What you showed me is VPN client access mode in RV042. I used the QuickVPN client to mount VPN tunnel successfully with certificate.
My question is for the VPN Client to Gateway mode, is it possible to authenticate with certificate file using SHREW soft ? how ?
hdam
02-27-2015 03:15 PM
Yes, you're right and sorry for that. According available configuration option for VPN Client to Gateway for both Tunnel and Group options it does not seem possible to use certificate. Certificate (RSA) authentication is alternative to Group (PSK) authentication and they both can't be combined together. And for Tunnel VPN option there is possible only to configure IKE with PSK.
You said that with QuickVPN you can use certificates, this points me to option with using Shrew Soft connecting with QickVPN-like style of VPN. Yes it could be possible, because QuickVPN is just classic IPSec tunnel with additional username/password authentication over HTTPS. This means that there is small chance to make it work. But I never tested and never will be because I am not owner of this RV042 router. For example in knowledge base article there is one screenshot of Shrew Soft client configuration with defined RV042 client certificate (coincidence? or could really work? I don't know).
I would suggest to:
