11-21-2011 07:58 AM
I have recently replaced an RV082 router that had failed with a new RV082. The previous router was set up to forward port 443 ssl requests to a server in the network. Worked flawlessly for years and that is why I replaced it with same model. The new router is also set up to forward port 443 ssl requests to the new server. The issue is that the router responds with its own certificate and does not forward the request to the server.
I am sure I am missing a simple setting but I can not find it and searching people with similar issues has not helped.
Your assistance would be greatly appreciated.
11-21-2011 08:11 AM
Have you tried the latest firmware 4.0.4.02-tm? (There is a known issue with forwarding port 443 in firmware 4.0.2.x or older.)
11-21-2011 09:37 AM
I have not but I will try that.
11-28-2011 08:39 AM
This did not solve the issue.
Is there another way to disable the router certificate as I need to resolve this issue quickly?
11-28-2011 08:48 AM
Please consider calling the Support Center to get the immediate attention.
11-28-2011 09:35 AM
Chris,
Disable the HTTPS under remote management even if remote managment is disabled; i have seen this cause your issue.
Also give us a call @ 1-866-606-1866 and open a support case.
Jasbryan
