[rv120w][IKE] ERROR: packet shorter than isakmp header size
genejohnson1958
Greetings!
First off, I am NOT very network savy so please bear with me..
My wife wanted to be able to VPN to her office from other computers.  I purchased the RV120W as it appeared that the QuickVPN would be sufficient for my wifes purposes.  I installed the RV120W at her office with no real problems.
I have managed to install the QuickVPN software on my Vista PC at home. Using this software...
I can make a connection, through my home router (a Linksys WRT54G), to the network at the office.
I can Ping one of the computers at the office using that computers known LAN IP Address.
I can enter the setup menus of the RV120W using it's LAN IP address (I can only enter these menus from the WAN IP address when not connected via the QuickVPN Software).
I can see my connection in the RV120W's VPN User Connection Status Table under the Status tab.
However,
I cannot see this connection on the RV120W's Dashboard under the VPN tab.
I cannot see any of the office computers, to include the one that I can ping, under Vista's "Network" page, I only see local LAN computers.
I cannot Ping any of the other computers at the office except for the one mentioned above.
I have provided both the Log file from the RV120W and the Log file from the QuickVPN Software..
Any suggestions, links, or comments would be greatly appreciated...
Jeff
I checked the Log File from  the RV120W and it shows a repetitive error:
2011-07-29 07:15:32: [rv120w][IKE] INFO: Adding IPSec configuration with identifier "wifeslogin"
2011-07-29 07:15:32: [rv120w][IKE] INFO: Adding IKE configuration with identifier "wifeslogin"
2011-07-29 07:15:43: [rv120w][IKE] INFO: Configuration found for (Home WRT54G WAN IP)[500].
2011-07-29 07:15:43: [rv120w][IKE] INFO: Received request for new phase 1 negotiation: (Office RV120W WAN IP)[500]<=>(Home WRT54G WAN IP)[500]
2011-07-29 07:15:43: [rv120w][IKE] INFO: Beginning Identity Protection mode.
2011-07-29 07:15:43: [rv120w][IKE] INFO: Received Vendor ID: MS NT5 ISAKMPOAKLEY
2011-07-29 07:15:43: [rv120w][IKE] INFO: Received Vendor ID: RFC 3947
2011-07-29 07:15:43: [rv120w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2011-07-29 07:15:43: [rv120w][IKE] INFO: Received unknown Vendor ID
2011-07-29 07:15:43: [rv120w][IKE] INFO: For (Home WRT54G WAN IP)[500], Selected NAT-T version: RFC 3947
2011-07-29 07:15:43: [rv120w][IKE] INFO: NAT-D payload matches for (Office RV120W WAN IP)[500]
2011-07-29 07:15:43: [rv120w][IKE] INFO: NAT-D payload does not match for (Home WRT54G WAN IP)[500]
2011-07-29 07:15:43: [rv120w][IKE] INFO: NAT detected: PEER
2011-07-29 07:15:44: [rv120w][IKE] INFO: Floating ports for NAT-T with peer (Home WRT54G WAN IP)[61884]
2011-07-29 07:15:44: [rv120w][IKE] INFO: ISAKMP-SA established for (Office RV120W WAN IP)[4500]-(Home WRT54G WAN IP)[61884] with spi:fde74473de3abba1:0a797e33d88a9ff9
2011-07-29 07:15:44: [rv120w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2011-07-29 07:15:44: [rv120w][IKE] INFO: Responding to new phase 2 negotiation: (Office RV120W WAN IP)[0]<=>(Home WRT54G WAN IP)[0]
2011-07-29 07:15:44: [rv120w][IKE] INFO: Using IPsec SA configuration: (My Home Vista PC's LAN IP)/24<->(A New Office LAN IP)/32
2011-07-29 07:15:44: [rv120w][IKE] INFO: Adjusting peer's encmode 3(3)->Tunnel(1)
2011-07-29 07:15:45: [rv120w][IKE] INFO: IPsec-SA established[UDP encap 61884->4500]: ESP/Tunnel (Home WRT54G WAN IP)->(Office RV120W WAN IP) with spi=199204161(0xbdf9d41)
2011-07-29 07:15:45: [rv120w][IKE] INFO: IPsec-SA established[UDP encap 4500->61884]: ESP/Tunnel (Office RV120W WAN IP)->(Home WRT54G WAN IP) with spi=3565951259(0xd48c191b)
2011-07-29 07:16:05: [rv120w][IKE] ERROR: packet shorter than isakmp header size.
2011-07-29 07:16:25: [rv120w][IKE] ERROR: packet shorter than isakmp header size.
2011-07-29 07:16:45: [rv120w][IKE] ERROR: packet shorter than isakmp header size.
This same error continued every few seconds through disconnecting at 08:01
2011-07-29 08:01:23: [rv120w][IKE] ERROR: packet shorter than isakmp header size.
2011-07-29 08:01:43: [rv120w][IKE] ERROR: packet shorter than isakmp header size.
2011-07-29 08:01:50: [rv120w][IKE] INFO: an undead schedule has been deleted: 'pk_recvupdate'.
2011-07-29 08:01:50: [rv120w][IKE] INFO: Purged IPsec-SA with proto_id=ESP and spi=3565951259(0xd48c191b).
2011-07-29 08:01:50: [rv120w][IKE] INFO: Purged ISAKMP-SA with proto_id=ISAKMP and spi=fde74473de3abba1:0a797e33d88a9ff9.
2011-07-29 08:01:51: [rv120w][IKE] INFO: ISAKMP-SA deleted for (Office RV120W WAN IP)[4500]-(Home WRT54G WAN IP)[61884] with spi:fde74473de3abba1:0a797e33d88a9ff9
2011-07-29 08:01:51: [rv120w][IKE] WARNING: no phase2 found for "wifeslogin"
2011-07-29 08:01:51: [rv120w][IKE] INFO: IPSec configuration with identifier "wifeslogin" deleted sucessfully
2011-07-29 08:01:51: [rv120w][IKE] WARNING: no phase1 found for "wifeslogin"
2011-07-29 08:01:51: [rv120w][IKE] INFO: IKE configuration with identifier "wifeslogin" deleted sucessfully
2011-07-29 08:01:51: [rv120w][IKE] ERROR: sainfo identifier not found ("wifeslogin")
2011-07-29 08:01:51: [rv120w][IKE] ERROR: Failed to Delete the IPSec configuration with identifier "wifeslogin"
2011-07-29 08:01:51: [rv120w][IKE] ERROR: remote identifier not found ("")
2011-07-29 08:01:51: [rv120w][IKE] ERROR: Failed to Delete the IKE configuration with identifier ""
2011-07-29 08:03:46: [rv120w][IKE] INFO: IPsec-SA expired: ESP/Tunnel (Home WRT54G WAN IP)->(Office RV120W WAN IP) with spi=199204161(0xbdf9d41)
I checked the log file from the QuickVPN Software and it shows the following:
  (Note there is approx a 5min difference in the two networks times)
2011/07/29 07:20:57 [STATUS]OS Version: Windows Vista
2011/07/29 07:20:57 [STATUS]Windows Firewall Domain Profile Settings: ON
2011/07/29 07:20:57 [STATUS]Windows Firewall Private Profile Settings: ON
2011/07/29 07:20:58 [STATUS]One network interface detected with IP address (My Home Vista Computers LAN IP)
2011/07/29 07:20:59 [STATUS]Connecting...
2011/07/29 07:20:59 [DEBUG]Input VPN Server Address = (Office RV120W WAN IP)
2011/07/29 07:20:59 [STATUS]Connecting to remote gateway with IP address: (Office RV120W WAN IP)
2011/07/29 07:20:59 [WARNING]Server's certificate doesn't exist on your local computer.
2011/07/29 07:21:02 [STATUS]Remote gateway was reached by https ...
2011/07/29 07:21:03 [STATUS]Provisioning...
2011/07/29 07:21:15 [STATUS]Success to connect.
2011/07/29 07:21:15 [STATUS]Tunnel is configured. Ping test is about to start.
2011/07/29 07:21:15 [STATUS]Verifying Network...
2011/07/29 08:07:20 [STATUS]Disconnecting...
2011/07/29 08:07:24 [STATUS]Success to disconnect.
Thanks Again,
Jeff
0 Replies 0
