RV130 Firmware 1.0.3.28
Mike Johnson
RV130 Issues with firmware 1.0.3.28
Uprading equipment from RV180 to RV130 and not able to set things the same.
1. Firewall custom service or port setting for "wan to lan" and "wan to dmz" will not let me block to "any"but asks for specific "to" ip only.
2. Will not let me select individual log policy to monitor or view. Selection will highlight all between from right to left.  Also when viewing logs selection highlighting is the same and will not let me filter a specific log.
3. Put computer in sleep mode while was logged in as admin and day later from same computer was able to click on dashboard to access admin menu options with no request for user and password.
Cisco I upgraded hardware but it seems was downgraded in the software.
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
I think it would be best if you could call our support line and open a support ticket, so we can do a WebEx remote session and check the configuration.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco TAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
