RV130 VPN configuration for Mac OS X devices
aeram1999
I have added the RV130 to our small office and I want to connect to the office network from home, with a Mac, over a VPN connection served by the RV130.
How do I setup the RV130 to do this?
How do I setup the VPN connection on the Mac ?
I tried following the VPN quick start wizard, tried the video that shows a green windows VPN client, but none of this works.
The logs show errors like: 'no suitable connection for peer' / 'sending encrypted notification INVALID_ID_INFORMATION'.
Thanks for any help / guidance in the right direction.
Aram
JP Miranda Z
Hi aeram1999,
This link is definitely going to help you:
https://supportforums.cisco.com/document/38941/qvpn-alternate-macsdocx
Hope this info helps!!
Rate if helps you!!
-JP-
