11-11-2014 01:05 PM
I just started a video game streaming business and have 4 video game consoles connected and able to play online at the same time on my recently purchased Cisco RV130W.
There's only 2 games currently that we are streaming but NAT seems to be a really big issue and is causing connection problems.
I've tried leaving this in the hands of UPnP but it seems that this is an issue that cannot be resolved so simply.
All 4 consoles are Sony PS4s and to connect and play online I need them all to have access to the following ports:
TCP Outbound | TCP Inbound | UDP Outbound | UDP Inbound |
80, 443, 1935, 3074-3077, 3478-3481,7500-17899, 10040-10060, 30000-40399 | 80, 443, 1935, 3074-3077, 3478-3481, 9293, 10040-10060 | 2001, 3074-3077, 3478-3481, 6000-7000, 10070, 50000-60000 | 2001, 3074-3077, 3478-3481, 6000-7000, 10070, 50000-60000 |
At best, I've got a NAT Type 2/Moderate... at worst, I can't even connect.
To answer any questions that may be coming up or rule out any suggestions I have already tried...
All help is appreciated. I will provide whatever other info you need.
Thank you in advance.
11-13-2014 09:46 AM
UPnP seems to be implemented very differently with the vendors
I would see if disabling the following on the firewall helps under Basic Settings
as they may also be part of the issue,
I know that Xbox Live likes to be able ping the wan IP, as for the PS I'd bet things are similiar
DoS Protection
Block WAN Ping Request
IPv4 Multicast Passthrough:(IGMP Proxy)
IPv4 Multicast Immediate Leave:(IGMP Proxy Immediate Leave)
UPnP Allow Users to Configure
UPnP Allow Users to Disable Internet Access
I know that Open Nat for Xbox is something you don't actually want,
as the ones who have open nat end up getting all the traffic, and they are the ones that get laggy
Unless the game they are playing has to be the server host there is no choice for the most part
Also, on most routers in regards to gaming, I've found that one should use UPnP or Port Triggering, but not both at the same time
