RV180W Wireless-N not working with MacBook
knealon20
Hi Folks,
I have an RV180W Wireless-N with firmware# 1.0.1.9
The problem is that any Macintosh computer will not work with the wireless network.
The problem is consistent with several MacBook laptops, running Leopard, Snow Leopard and Mountain Lion.
The MacBook connects with the wireless network and obtains an IP address.
However when the MacBook tries to access a web page, it fails loads.
Accessing LAN assets like network volumes and printers works fine.
All mobile devices, such as iPhones, iPods and iPads work fine.
I have tried numerous wireless settings on the router and the MacBooks and nothing works.
The problem happens regardless of what kind of wireless security is present.
There is not MAC filter.
Tom Watts
What happens if you wire in to the router, does the internet work fine?
Have you also checked DNS settings on both the computer and router?
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
