12-05-2011 02:10 AM
We have 2 VLANs configured to keep 2 groups of PCs apart. Is it possible to allow both VLANs to access the same printer without allowing other traffic between these VLANs ?
Any advice would be much appreciated.
12-05-2011 02:54 AM
You should be able to yes, when you setup the printer use the IP address as its printer port and it should work fine.
12-05-2011 04:08 AM
Thanks for the reply Simon.
Should I place the printer in a third VLAN (as opposed to one of the exclusive VLANs containing the PCs)? If so, will it be enough to enable"Inter VLAN Routing" on this third 3rd VLAN only?
12-05-2011 01:34 PM
yes you can do that if you want. i did setup my home lan that way.
