RV320 and WAN VLAN tagging/IPTV
fabioatcisco
I have a fiber connection on WAN1 which only works with VLAN tagging and I can't find a way to make it work without the provider's middleware router (Comtrend C5813)... Is there a way to connect to my FTTH (Lucent I240G-B) router directly? I'm having problems with my IPTV (multicast) service, if it's connect direct to the middleware I can have multiple channels running at once, but if I go back to the RV320 and do the same, everything start to pixelate.
Using Wireshark I can see that the RV320 is connecting to the different channels with CS4 DSCP marking.
Any ideas?
Thank you!
SamirD
Level 5
Level 5
What are you trying to accomplish by removing the comtrend?
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
As you can read above, I'm having problems with my IPTV pixelation/cuts... I need to be able to connect directly to the fiber and have more control over the connection, but I don't see the option on the web admin for PPPOE over VLAN. I don't know if it's a hardware limitation or just software (the GUI).
You can't do pppoe over vlan.  It's not a part of the feature set.
What does your network diagram look like?  Maybe there's another way to solve the problem.
renanrduarte
same problem:
https://supportforums.cisco.com/discussion/12357081/rv320-vlan-wan-port
