RV340 - AnyConnect licensing
Viktor Jahna
When I connect RV340 to Smart Licensing Manager, -2 licenses appear and nobody will connect via AnyConnect, although:
* The platform includes two AnyConnectVPN session licenses. The first two sessions in the count do not require licenses from Smart Software Licensing Manager.
Without connecting to the Smart Licensing Manager you can connect only twice. I thought there were two simultaneous connections, and after the disconnection, another one could connect?
ktonev
Hi Viktor,
Please try to untick the "Enable" for Anyconnect VPN as per the screenshot below. You can find this menu by clicking the "Choose Licenses" button in the License section. This should resolve the -2 issue you are seeing. Yes, you are correct in saying that by default you should be able to have 2 simultaneous connections to the RV router via AnyConnect.
ktonev
Hi Viktor,
As seen in the previous screenshot, you can't  untick the "Enable" for Anyconnect VPN.
So actually what is the solution?
