RV345 multiple IPs on WAN1 via WAN1.1 1.2 etc... port forwarding problems
cjfirm-patrick
I have turned off the firewall to eliminate that as a culprit and set the appropriate port forwarding rules using WAN1.1 as the interface instead of WAN1.  If I set it to WAN1, I can reach the local server on public ip .57, if I set it to WAN1.1 I can't reach it on .58 using the same internal ip.  Any suggestions?
My config is as follows:
WAN1
Static IP: x.x.x.57
Subnet: 255.255.255.248
GW: x.x.x.62
WAN1.1
Static IP x.x.x.58
GW: x.x.x.62
WAN1.2
Static IP x.x.x.59
GW: x.x.x.62
WAN1.3
Static IP x.x.x.60
GW: x.x.x.62
0 Replies 0
