Subnets or masks issue?
Alejandro Gidi
Dear Network Gurus
What looked like a simple setup is giving us a headache
RouterA rv016 on 192.168.0.1/255.255.255.0 VPN gate to gate to RouterB rv082 with 192.168.1.1/255.255.255.0 , NAT transversal is enabled.
IPPBX on 192.168.0.10, Tel on 192.168.1.100, won't reach the PBX, we can ping from/to without problems.
We can ping the PBX with 192.168.0.10 from the lan with 192.168.1.1
We can ping the phone with 192.168.1.100 from the lan with 192.168.0.1
Ideas, tests, pointers, all appreciated.
thanks
Te-Kai Liu
Level 7
Level 7
What's your WAN connection type on RV016 and RV082?
Do you use protocol binding at all?
You might want to give SBSC a call to deal with issues like this.
Alejandro,
If the tunnel is up and the ping is going through it could be a phone configuration issue or a SIP issue.  What is the problem with the phones? do they not register? or is it communication between two PBX's?
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
Randy, tekliu
The phones have DHCP, when there are placed on the 192.168.0.1, they get their IP, register and work without a problem.
When they are transported to the branch with the 192.168.1.1 network, they get their IP, but wont reach the PBX.
I can ping the PBX from that network , and can ping the phone from the other one.
We have found that enalbing Multiple Subnet on the RV016, and adding 192.168.1.0/255.255.255.0 hampers the funcionality of the VPN. We can ping the branch RouterB, but the branch cant ping the RouterA.
thanks
Alejandro,
I think it is a routing issue from what I can see so far, but we would need to see a network diagram to confirm this. It might also speed up the process if you called in and created a case and worked with an engineer on this issue. 1866-606-1866.
Randy Manthey
