02-24-2020 08:52 PM
I have a site running a rv042 small business VPN router. It is not passing PCI compliance scans because it has expired certificates, and old tls, etc etc.
I downloaded new firmware "RV0XX_v4.2.3.10_20191004-code.bin" and it uploads but then just goes to a browser screen showing an empty response, doesn't seem like the router ever goes down or restarts. just doesn't do anything....
xxx.xxx.xxx.xxx didn’t send any data.
02-24-2020 09:03 PM - edited 02-24-2020 09:04 PM
these are the errors the PCI Scan is finding i need to resolve....
SSL Certificate - ExpiredLearn More 60443 tcp Certificate #0 SN=California,L=Irvine,C=US,O=Cisco-Linksys\,_LLC,OU=RV042,CN=00:16:b6:89:a ...
SSL Server Supports Weak Encryption VulnerabilityLearn More 60443 tcp CIPHER KEY-EXCHANGE AUTHENTICATION MAC ENCRYPTION(KEY-STRENGTH) GRADE SSLv2 WEAK CIPHERS ...
Deprecated Public Key LengthLearn More 60443 tcp Certificate #0 RSA Public Key (1024 bit) RSA Public-Key: (1024 bit) Modulus: 00:b4:fc:2a:d ...
SSL Server Has SSLv2 Enabled VulnerabilityLearn More 60443 tcp Established SSLv2 connection using DES-CBC3-MD5 cipher.
SSLv3.0/TLSv1.0 Protocol Weak CBC Mode Server Side Vulnerability (BEAST)Learn More 60443 tcp Available non CBC cipher Server's choice SSL version RC4-SHA DES-CBC3-SHA SSLv3 RC4-S ...
SSL/TLS use of weak RC4(Arcfour) cipherLearn More 60443 tcp CIPHER KEY-EXCHANGE AUTHENTICATION MAC ENCRYPTION(KEY-STRENGTH) GRADE SSLv2 WITH RC4 CIPHE ...
SSL Certificate - Signature Verification Failed VulnerabilityLearn More 60443 tcp Certificate #0 SN=California,L=Irvine,C=US,O=Cisco-Linksys\,_LLC,OU=RV042,CN=00:16:b6:89:a ...
TLS ROBOT Vulnerability DetectedLearn More 60443 tcp ROBOT vulnerability found on TLSv1 with a weak oracle
SSL/TLS Server supports TLSv1.0Learn More 60443 tcp TLSv1.0 is supported
SSLv3 Padding Oracle Attack Information Disclosure Vulnerability (POODLE)Learn More 60443 tcp
SSL Server Has SSLv3 Enabled VulnerabilityLearn More 60443 tcp SSLv3 is supported
02-24-2020 09:17 PM
02-24-2020 09:19 PM
02-24-2020 09:34 PM
