Updating Firmware - Issues
sharejss1
I recently updated firmware from 1.04 to 1.05..8.  With old setup, I had separate DHCP coordinated with devices MAC address.  But, now after completing an Angry IP Scan, the the DHCP IP's do not coordinate with prior setup.  I have checked with my ISP and there is nothing unusual going on my modem IP address
Do I need to complete a full factory reset and add back all of the information?  Any ideas would be helpful.
mpyhala
Level 7
Level 7
Jeffrey,
Please be more specific. Do you mean that the devices are getting an IP from a different network or that the MAC address is not matching the assigned IP?
Regarding your last question, reconfiguring from factory defaults is always a good idea if you are experiencing problems after a firmware upgrade. Depending on the configuration it may be easier and less time consuming to troubleshoot the issue directly.
- Marty
Marty:  Thanks.  A Full reset addressed the issue.
SamirD
Level 5
Level 5
This is why you never save and restore settings when doing firmware updates.  Strange things like this can happen.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
