12-05-2009 09:16 AM
Few days ago i bought WRVS4400N and i tried to connect it to my ISP which is working only on PPPoE connection. Unfortunately we wasn't able to make it work. Please see below the log of the router when i try to connect via PPPoE:
Plugin pppoe loaded.
PPPoE Plugin Initialized
Plugin pppoe called.
pppd 2.4.1 started by root, uid 0
Sending PADI
HOST_UNIQ successful match
Unexpected packet: Ether addr: 00:16:76:c8:08:fc (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0030 (PADO) PPPoE tag: type=0102 length=0008 (AC Name) data (UTF-8): raspppoe PPPoE tag: type=0101 length=0000 (Service name) P
Unexpected packet: Ether addr: 00:16:76:c8:08:fc (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=0006 (AC Name) data (UTF-8): r1-bor PPPoE tag: type=0101 length=0000 (Service name) PPP
Unexpected packet: Ether addr: 00:16:76:c8:09:8e (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=0006 (AC Name) data (UTF-8): r5-bor PPPoE tag: type=0101 length=0000 (Service name) PPP
Unexpected packet: Ether addr: 00:16:76:c8:09:8e (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0030 (PADO) PPPoE tag: type=0102 length=0008 (AC Name) data (UTF-8): raspppoe PPPoE tag: type=0101 length=0000 (Service name) P
Unexpected packet: Ether addr: 00:16:76:c7:f4:a2 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0030 (PADO) PPPoE tag: type=0102 length=0008 (AC Name) data (UTF-8): raspppoe PPPoE tag: type=0101 length=0000 (Service name) P
Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x427d8
Couldn't get channel number: Transport endpoint is not connected
Doing disconnect
Exit.
Please let me know if you need additional info. Your help is really appriciated!! Thank you!!!
12-11-2013 01:33 AM
Still no solution ? This device is a big fail for a SMB Router , i had to take LANCOM they are PROs and everything works fine with LANCOM AP and Routers
