Patrick Born
This document describes how to configure both Broadsoft and the SPA5xxG IP phone for BLF, manually and with BLF List URI.
The document also describes how to configure and use call pickup (CP), both group call pickup and directed call pickup.
bgottlieb
Patrick,
This is a nice document, but should also include using the BLF "list" URI subscription. It is much easier to provision when monitoring alot of users and is dynamic (i.e. if the Broadsoft BLF changes, the phone changes with it). There is one MAJOR drawback to doing the "list" method though... When the initial NOTIFY is received, the phone fills in all of the users in the list with only blf+cp, not blf+cp+sd. I REALLY wish this would get resolved, as it would make provisioning BLF's that much easier.
- Bill
adameliasen
Community Member
I agree, blf+cp+sd should be used by the "list" method.
Has anyone been able to get directed call pickup to work.
Adam
adameliasen
Community Member
Great News! I notice the follwing in the 7.4.4 release notes:
"Added speed-dial function to BroadSoft auto-busy lamp field key. (SIP)"
I haven't had the chance to test it yet.
Directed Call Pickup from BLF
I'm having problem with the CallPickup with Broadworks. When I press a blinking BLF button the phone only dials *98, not *98<extension>.
I have also tried defining "Attendant Console Call Pickup Code" = *98# as suggested on some Asterisk forums without success.
I define the according the documentation:
fnc=sd+blf+cp;sub=monitoring-phone@bsblf.com;usr=4085558001@bsblf.com
Any suggestions?
regards,
Adam
bgottlieb
Adam,
That is indeed good news.. I will try out the new s/w ASAP.
In regards to the call pickup, I have found it to work with no issues. Remember it is not doing a "directed" call pickup on the incoming line.. It is doing a "group" call pickup. Assign your BLF user in a Call Pickup Group along with all of the users that the user is monitoring. When an incoming call comes into one of the monitored users, pressing a flashing button causes the phone to dial a "*98" which picks up the incoming call....
Hope that helps...
- Bill
adameliasen
Community Member
Bill,
Thanks for your answer. The group call pickup would work in most cases. The problem is if there are two calls coming in at the same time it is difficult to know which one you are answering.
I was hoping for directed call pickup support for Broadworks with the syntax "*97#", where # whould resolve to the blinking extension.
This seems to be supported for Asterisk BLF according to the following link (see bottom of the page):
http://www.yourexodus.com/index.php?option=com_content&view=article&id=80:spa962-spa942-and-blf-busy-lamp-field&catid=45:articles&Itemid=88&fontstyle=f-smaller
-adam
bgottlieb
I agree. *98 always picks up the "first" incoming call (i.e. if there were 3 incoming calls, it would pick up the one that was ringing the longest...)
- Bill
smartnet
Unfortunatly, this is not working . We have a problem with blf on spa504g phone with broadsoft on tcp only.
The spa504g is not learning the Record-Route within our 200 OK (for the first Subscribe). It must set its route set (Route header) to match the list of URIs in the Record-Route header sent in the response.
