Objective
This article guides in editing or deleting speed dial numbers on the WIP310-G1.
To make phone calls with one tap option, you can use the speed dial option to have up to 98 speed dial numbers. The Speed Dial 1 is reserved for voice mail and is not editable.
Applicable Devices
• WIP310 G1
Step-by-Step Procedure
Edit or Delete a Speed Dial Number
Step 1. On the Home Screen, Press the Center button of the navigation pad..
Step 2. On the Navigation pad press the select button to see the Setting menu options.
Step 3. Press the Left or Right Arrow key to select Speed Dial.
Step 4. Scroll Up or Down to navigate an Speed Dial number slot.
Step 5. The number wish to edit or delete. Press the Options soft key.
Step 6. Press the Up or Down arrow key to navigate to Remove Entry, Edit or Edit Dial. Press the Select button.
• Select Edit to edit the speed dial name.
• Select Edit Dial to edit the speed dial number.
• Select Remove Entry, press Ok. The message "Are you sure?" appears.
Step 6. Press the Select button to confirm.
