Objectives
Firmware Upgrade WIP310-G1 Phone which helps the user to clear blank screen issue.
This article explains how to upgrade the firmware WIP310-G1 Phone.
Applicable Devices
  • WIP310-G1 iPhone
Software Download URL
WIP310-G1 iPhone
Steps of Procedure
Step 1. Using the device, choose MENU > Settings > Phone info > Software Version to check the software version of the device.
Step 2. Check for the latest version available on www.cisco.com. Download the latest version to upgrade.
Step 3. Switch off the phone and connect the phone to a computer using a USB cable through which the firmware will be upgraded. Double click the executablefile from the download.
Note: The executable is compatible with Windows XP and Windows Vista.
Step 4. Check the version after the upgrade is done to verify the upgrade was done correctly, choose MENU > Settings > Phone info > Software Version to check.
