www.cisco.com
WAP121 Wireless-N Access Point with Single Point Setup
Online Device Emulator (ver. 1.28.3.40)
- Affordable wireless N connectively, offers 2x2 MIMO technology
- Sleek, elegant design with flexible mounting options (Wall, Celling, or Desktop)
- Power Over Ethernet support for lower deployment cost and easy installation
- Simplified configuration and management of multiple access points using Single Point Setup, a controller-less technology
_____________________________________
www.cisco.com
WAP131 Wireless-N Dual Radio Access Point with PoE
Online Device Emulator (ver. 1.0.1.3)
Online Device Emulator (ver. 1.0.0.39)
- Dual Radio 2.4 and 5Ghz Wireless N connectivity
- Standalone access point
- Desktop design with integrated stand for easy access and placement
- 1 Gigabit Ethernet LAN w/PoE
- Simple installation and intuitive web-based configuration.
WAP321 Wireless-N Selectable-Band Access Point with Single Point Setup
Online Device Emulator (ver. 1.0.2.3)
Online Device Emulator (ver. 1.0.0.3)
www.cisco.com
WAP351 Wireless-N Dual Radio Access Point with 5-Port Switch
- Single Point Setup a controller less technology for easy manageability
- 5- Port Gigabit Ethernet Switch supporting both PD and PSE, allowing IP devices and the AP to be powered by a backbone switch
www.cisco.com
WAP371 Wireless-AC/N Dual Radio Access Point
Online Device Emulator (ver. 1.2.0.2)
Online Device Emulator (ver. 1.0.1.5)
- Dual radio802.11ac wireless access
- Simple installation and easy deployment
- Single Point Setup support
- Captive portal support
- Robust security
supportforums.cisco.com
WAP551 Wireless-N Single Radio Selectable Band Access Point
Online Device Emulator (ver.1.2.0.2)
- Selectable dual-band (1 radio)
- Captive Portal Support
- SmartSignal Antenna
- Robust security
www.cisco.com
WAP561 Wireless-N Dual Radio Selectable Band Access Point
Online Device Emulator (ver.1.1.0.4)
Online Device Emulator (ver.1.0.4.4)
Online Device Emulator (ver.1.0.4.1)
- Selectable or concurrent dual-band radio.
- Single Point Setup.
- Captive portal support.
- SmartSignal Antenna.
- Robust security.
AP541N Wireless Access Point
Online Device Emulator (ver. 1.9.2)
Learn more about Cisco Small Business Wireless Access Points
