streaves
Download SG300-52 to host the emulator locally.
Unzip the file and double click- ../config/home_SG_300-52_1_2_9.htm to launch the emulator.
Please use IE browser only. If you see warning message that restricts scripts or ActiveX controls from running, click "Allow blocked content" to continue.
Command Line Interface (CLI) Emulator for 300 Series Switches
Get familiar with the new CLI interface without actually being connected to a switch in real-time. Download and unzip the file to your computer and click on the 'run_SG300_28_AlleyCat_SA.bat' file.
Default username:cisco
Default password: cisco
Also see:
pctekuruguay
No es posible la descarga de ninguno de los zip...!!!???
ChrisGabrielC
SG_300-28P_v1_1.zip works great. (thanks)
SF_300_48P_Online_Device_Emulator.zip is SF-300-24P ... and the dev will have to update the path on the index page and several other in order to make it function properly.
