Andrew Hickman
You can find details of which applications are included or installed on BE6000 products from the build summaries posted on the BE6000 Release Notes page.
Separate files are provided for the BE6000S appliance and BE6000 rack servers with either encrypted (K9) or non-encrypted (XU) software loads.
Similar build summaries are also provided for BE7000 rack mount servers on the BE7000 Release Notes page.
How are we doing?  Do these files help you?  Are we missing anything?  Let us know by commenting below!
christoph.hable
Hi Andrew!
1) When will the separate files for BE6000S be published? :)
2) It would be great to use the Notification Service for the software loads - any approach to deal with this feature?
   Maybe simply upload the PDF into the Download Area in the BE6000 areas, hence all Partners are able to receive dedicated notifications about new software loads.
3) It would be great to know if there is a new SW Load release how we can identify when a newly placed order will receive this new load from ordering  state (CCW) or delivery state.
4) Enable Partners to quickly order a hard disk(s) only for BE6000 and BE6000S to have easily the new loads (and the pre-configured images). Rather helpful for partners with dedicated stock.
5) Publish the pre-configured images on SW Download center.
BR,
Christoph
Andrew Hickman
Thanks for the feedback Christoph,
By coincidence, I noticed that this was missing earlier too.  I'll work with the team to get this fixed as soon as possible.  The summary will be posted in the same place.
Andy
Andrew Hickman
Hi Christoph,
Software summary for the BE6000S is now posted:
http://www.cisco.com/c/en/us/support/unified-communications/business-edition-6000/products-release-notes-list.html
Thanks for the prompt!
Andy
