Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
How to Manually Reload or Reset a Switch through the Command Line Interface (CLI)
Objective
The Reload function of the Cisco Small Business Switches is useful when certain changes in the settings require a reboot to completely apply the configuration settings, or if the device is not functioning as expected. The configuration settings of the network device get reflected after the device restarts.
The Reset feature is used to remove the running or current configuration settings on the network device and restore it to the original default settings. Manual reset is recommended when the whole device needs to be reconfigured, or in case you forget the password and not able to recover by any means such as accessing the console using Telnet, Secure Shell (SSH), or Command Line Interface (CLI).
This article provides instructions on how to manually reload or reset your switch through the CLI.
Applicable Devices
Sx300 Series
Sx350 Series
SG350X Series
Sx500 Series
Sx550X Series
Software Version
1.4.7.05 — Sx300, Sx500
2.2.8.4 — Sx350, SG350X, Sx550X
Manually Reload the Switch through the CLI
Note: The available commands may vary depending on the exact model of your device. In this example, SG350X-48MP switch is used.
Step 1. Log in to the switch console. The default username and password is cisco/cisco. If you have configured a new username or password, enter the credentials instead.
Note: In this example, the switch is accessed through SSH.
Important: When a switch is reloaded, the running configuration file is deleted. Before proceeding with the reload instructions, make sure to save all the running configuration settings to avoid data loss.
Step 2. In the Privileged EXEC mode of the switch, save the configured settings to the startup configuration file, by entering the following:
Note: If you wish to proceed without saving the running configuration settings, skip to Step 4.
Step 3. Press Y for Yes or N for No on your keyboard once the Overwrite file [startup-config]… prompt appears.
Note: In this example, Y is pressed.
Step 4. To reload the switch, enter either of the following commands:
reload — Use the reload command to reload the switch immediately.
reload {{in hhh:mm | mmm | at hh:mm [day month]}} — Use this command to specify scheduled switch reload.
- in hhh:mm | mmm — Schedules a reload of the image to take effect in the specified minutes or hours and minutes. The reload must take place within approximately 24 days.
- at hh:mm — Schedules a reload of the image to take place at the specified time by using a 24-hour format. If you specify the month and day, the reload is scheduled to take place at the specified time and date. If you do not specify the month and day, the reload takes place at the specified time on the current day (if the specified time is later than the current time) or on the next day (if the specified time is earlier than the current time). Specifying 00:00 schedules the reload for midnight. The reload must take place within 24 hours.
Note: This option can only be used if the system time settings of the switch have been configured. To learn how, click here for instructions.
- day — Number of the day in the range from 1 to 31.
- month — The month of the year in the range from Jan to Dec.
Note: In this example, reload at 10:00 11 Apr is used.
Step 5. Press Y for Yes or N for No on your keyboard once the This command will reset the whole system and disconnect your current session prompt appears.
Step 6. (Optional) To display information about a scheduled reload, enter the following:
Step 7. (Optional) To cancel the scheduled reload, enter the reloadcancel command.
You will be notified that the scheduled reload was aborted.
You should now have successfully reloaded your switch through the CLI.
Note: In the example below, the immediate reload is used and Y is entered on both questions.
Manually Reset the Switch
When the switch fails to work and cannot be reset by using the web-based utility, the switch can be manually reset to restore the factory default configuration.
Step 1. Disconnect all Ethernet cables from the switch.
Step 2. Using a pin, press and hold the Reset button on the switch for 15 to 20 seconds.
Note: In this example, SG350X-24 24-Port Gigabit Stackable Managed Switch is used.
Step 3. Once all the port Light-Emitting Diodes (LEDs) light up, release the Reset button.
Note: Telnet and SSH services are disabled by default. You will have to access the console of the switch using the computer that is directly connected to your switch through the serial cable.
Step 4. Connect your computer directly to the switch using a serial cable.
Step 5. Log in to the switch console. The default username and password is cisco/cisco. If you have configured a new username or password, enter the credentials instead.
Step 6. You will be prompted to configure new password for better protection of your network. Press Y for Yes or N for No on your keyboard.
Note: In this example, Y is pressed. If N is pressed, skip to Step 9.
Step 7. (Optional) Enter the old password then press Enter on your keyboard.
Step 8. (Optional) Enter and confirm the new password accordingly then press Enter on your keyboard.
Step 9. Enter the Global Configuration mode of the switch by entering the following:
Step 10. (Optional) To change the hostname of your switch, enter the following:
Note: In this example, SG350X is used.
Step 11. (Optional) To enable the Telnet service on your switch, enter the following command:
Step 12. (Optional) To enable the SSH service on your switch, enter the following command:
You should now have successfully reset the switch manually. To learn how to assign an IP address on your switch through the CLI, click here.
