smallbusiness
Community Manager
Community Manager
Article ID:5642
Install Cisco AnyConnect Secure Mobility Client on a Mac Computer
Objective
The Cisco AnyConnect Secure Mobility Client provides remote users with secure Virtual Private Network (VPN) connection. It provides remote end users with the benefits of a Cisco Secure Sockets Layer (SSL) VPN client, and supports applications and functions not available on a browser-based SSL VPN connection. Commonly used by remote workers, AnyConnect lets them connect to the corporate computer infrastructure as if they were physically at the office, even if they are not. This adds to the flexibility, mobility and productivity of the workers.
Note: Cisco AnyConnect is compatible with the following operating systems:
  • Windows 7, 8, 8.1, and 10
  • Mac OS X 10.8 and later
  • Linux Intel (x64)
The Cisco AnyConnect Secure Mobility Client can be downloaded for free, however, you need to have client licenses to use it. Client licenses are sold in packs of 25. The connection licenses included in the RV340, RV345, and RV345P are not client licenses. An evaluation version of the Cisco AnyConnect Secure Mobility Client is not available for the devices mentioned, since they are not considered as Adaptive Security Appliances (ASAs). But you can still use the VPN facilities of these devices for your VPN needs.
This article aims to show you how to install the Cisco AnyConnect Secure Mobility Client on a Mac Computer. If you are using a Windows computer, click here.
Applicable Devices
  • AnyConnect Secure Mobility Client
Software Version
  • 4.3
Install AnyConnect Secure Mobility Client
Step 1. Download AnyConnect here.
Step 2. Double-click the installer.
Step 3. Click Continue.
Step 4. Go over the Supplemental End User License Agreement and then click Continue.
Step 5. Click Agree.
Step 6. Choose the components to be installed by checking or unchecking the corresponding check boxes. All components are installed by default.
Step 7. Click Continue.
Step 8. (Optional) Click Change Install Location to manually specify the path to install AnyConnect.
Step 9. Click Install.
Step 10. (Optional) Enter your password in the Password field.
Step 11. Click Install Software.
Step 12. Click Close.
You should now have successfully installed the AnyConnect Secure Mobility Client Software on your Mac computer.
