Dear,
We need you help of the network layout below.
equipment
RV082 x 4 pcs
At the network connectivity, each RV082 have one broadband connection and DHCP server enabled and the router ip within the same subnet so we make it inter-connect with each router.
For the network setting, we desires it sharing the resource within the LAN and uses the different internet connection which selected by router lan port we are plugged in. The problem now is when i plugged into router no.1 lan port but can't get the ip address from no.1 and it may be no. 2 or 3.
Would you please to help to make it available on uses 4 x RV082 to share the resources within each other and use the different internet connection which selected by router lan port we are plugged in.
Thanks alot.
