RyanPeel18972
Hello.  Is there a way to compile a custom firmware that contains a TR-069 url into it?  We use the latest 1.41 firmware right now.
mumagraw
Hi Ryan,
My name is Mumal Agrawal from the cisco Small Business TAC.
No, there is no way we can compile a custom firmware that contains a TR-069 url into it.
Also, for more details, you can get a new service request opened with cisco by calling our frontline number mentioned in the link below:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
We will be happy to help you.
Thanks!
Dan Lukes
While custom firmware is not possible (but it's just about size of the order - call Cisco sales department) the SPA112 still supports zero touch provisioning. It may or may not help you (you didn't disclosed the details of your environment).
RyanPeel18972
Do you have a contact at cisco sales?
Dan Lukes
Start here: https://www.cisco.com/c/en/us/about/contact-cisco.html/request-quote-buy-products-services/potential-customer-guest
But note the SPA112 is declared EoL  (The last day to order is June 1, 2020). and it's out of stock already. So your chances are low even for very large orders.
You should consider ATA191-3PW-K9 instead. Moreover it claims support for zero-touch provisioning via TR-069.
