Dan Lukes
Provisioning or XML address book may be configured to use SSL (HTTPS) connection. Such secure connection may fail for some reason. For the purpose of debugging, you need to turn on debug messages, level 3 or more. Debug messages will look like the following:
local3.debug | [create_tcp_netstrm1] use async to create tcp connection
local3.debug | connect succeed
local3.debug | [create_tcp_netstrm1] connect SUCCEED
local3.debug | ssl cert err 20
local3.debug | create ssl connection failed
The "ssl cert err N" show the SSL error and reveal the cause for failed SSL connection.
The following table summarise possible N values, their names and (in some cases) a description of it. The list of possible error and their names has been taken from OpenSSL sources (x509_vfy.h). Descriptions are mine.
NNameDescription
0X509_V_OK
2X509_V_ERR_UNABLE_TO_GET_ISSUER_CERT
3X509_V_ERR_UNABLE_TO_GET_CRL
4X509_V_ERR_UNABLE_TO_DECRYPT_CERT_SIGNATURE
5X509_V_ERR_UNABLE_TO_DECRYPT_CRL_SIGNATURE
6X509_V_ERR_UNABLE_TO_DECODE_ISSUER_PUBLIC_KEY
7X509_V_ERR_CERT_SIGNATURE_FAILUREmostly because of unsupported certificate hash alghoritm. Use SHA1 or MD5 only
8X509_V_ERR_CRL_SIGNATURE_FAILURE
9X509_V_ERR_CERT_NOT_YET_VALIDcertificate not valid yet - check time on phone
10X509_V_ERR_CERT_HAS_EXPIREDcertificate expired - check time on phone
11X509_V_ERR_CRL_NOT_YET_VALID
12X509_V_ERR_CRL_HAS_EXPIRED
13X509_V_ERR_ERROR_IN_CERT_NOT_BEFORE_FIELD
14X509_V_ERR_ERROR_IN_CERT_NOT_AFTER_FIELD
15X509_V_ERR_ERROR_IN_CRL_LAST_UPDATE_FIELD
16X509_V_ERR_ERROR_IN_CRL_NEXT_UPDATE_FIELD
17X509_V_ERR_OUT_OF_MEM
18X509_V_ERR_DEPTH_ZERO_SELF_SIGNED_CERT
19X509_V_ERR_SELF_SIGNED_CERT_IN_CHAINself signed certificate not recognized as trusted
20X509_V_ERR_UNABLE_TO_GET_ISSUER_CERT_LOCALLYchain root certificate not recognized as trusted or intermediate certificate not supplied by SSL server
21X509_V_ERR_UNABLE_TO_VERIFY_LEAF_SIGNATURE
22X509_V_ERR_CERT_CHAIN_TOO_LONG
23X509_V_ERR_CERT_REVOKED
24X509_V_ERR_INVALID_CA
25X509_V_ERR_PATH_LENGTH_EXCEEDED
26X509_V_ERR_INVALID_PURPOSE
27X509_V_ERR_CERT_UNTRUSTED
28X509_V_ERR_CERT_REJECTED
29X509_V_ERR_SUBJECT_ISSUER_MISMATCH
30X509_V_ERR_AKID_SKID_MISMATCH
31X509_V_ERR_AKID_ISSUER_SERIAL_MISMATCH
32X509_V_ERR_KEYUSAGE_NO_CERTSIGN
33X509_V_ERR_UNABLE_TO_GET_CRL_ISSUER
34X509_V_ERR_UNHANDLED_CRITICAL_EXTENSION
35X509_V_ERR_KEYUSAGE_NO_CRL_SIGN
36X509_V_ERR_UNHANDLED_CRITICAL_CRL_EXTENSION
37X509_V_ERR_INVALID_NON_CA
38X509_V_ERR_PROXY_PATH_LENGTH_EXCEEDED
39X509_V_ERR_KEYUSAGE_NO_DIGITAL_SIGNATURE
40X509_V_ERR_PROXY_CERTIFICATES_NOT_ALLOWED
41X509_V_ERR_INVALID_EXTENSION
42X509_V_ERR_INVALID_POLICY_EXTENSION
43X509_V_ERR_NO_EXPLICIT_POLICY
44X509_V_ERR_DIFFERENT_CRL_SCOPE
45X509_V_ERR_UNSUPPORTED_EXTENSION_FEATURE
46X509_V_ERR_UNNESTED_RESOURCE
47X509_V_ERR_PERMITTED_VIOLATION
48X509_V_ERR_EXCLUDED_VIOLATION
49X509_V_ERR_SUBTREE_MINMAX
50X509_V_ERR_APPLICATION_VERIFICATION
51X509_V_ERR_UNSUPPORTED_CONSTRAINT_TYPE
52X509_V_ERR_UNSUPPORTED_CONSTRAINT_SYNTAX
53X509_V_ERR_UNSUPPORTED_NAME_SYNTAX
54X509_V_ERR_CRL_PATH_VALIDATION_ERROR
Notes:
  1. Certificate used by SSL connection needs to be issued by an authority preconfigured in phone by Cisco (see SPA Certificate Authority (CA) List for more information). With firmware >=7.5.1 a certificate authority configured via "Custom CA Rule" option can be used as well (see Administrator's guide for more informations).
  2. SPA[35]xx accepts certificates even they are expired or not valid yet. SPA[12]xx ATA devices with firmware < 1.3.2 ignore verification result at all, any certificate is considered valid.
