Patrick Born
Ever wish you had a syslog server available so you could capture syslog messages from your network devices for analysis when troubleshooting?
The slogsrv.exe is what you need. The slogsrv.exe syslog server file is attached as slogsrv.zip
Summary:
1. Determine the IP address of your computer from a command prompt:
c:\ ipconfig /all
Take note of the computer's IP address, you will use this address shortly.
2. Run the slogsrv.exe syslog server by either double-clicking on it or running it directly from the Command Prompt.
Do not close the window that the syslog server is running in, else you will terminate the syslog server and will not log syslog messages.
Your server is now ready to receive syslog messages from network devices and will log the messages in the syslog.514.log file in the same directory that the slogsrv.exe file is located.
3. Configure your devices to send syslog messages to the IP address from #1.
4. You can view the syslog.514.log file with any text editor or send the file to your support expert for analysis.
Details about the slogsrv.exe server:
Usage: slogsrv [-p port] [-o filename] [-t] [-h]
Where:
-p port          specify the listening port, default "514"
-o filename    specify the output file name, default syslog.port.log
-t                  turn the local timestamp and parse the syslog header
-h                this help
Other documents of interest:
1. Configuring syslog and debug on the SPA9000
2. Configuring syslog and debug on the SPA9xx, SPA525G, & WIP310 IP phones
3. Configuring syslog and debug on the SPA400
4. Configuring syslog and debug on SPA Analog Telephone Adaptors (ATA)
5. Configuring syslog and debug on SPA1xx ATAs
<end>
c.hulcher
Patrick, is there a reason to use this utility versus the Kiwi Syslog Daemon?
Patrick Born
No, you can use any syslog utility that you're comfortable with.
Nice to have include date/time stamping, but most utilities do that anyway.
Patrick
quesse
anyone know how to setup syslog server IP in linksys WRP400 config?
thanks
cindy toy
Level 7
Level 7
Hi Luca,
This is not the area to ask a question. I suggest you post the same question in the ATA, Gateways, and Accessories area: https://supportforums.cisco.com/community/netpro/small-business/voiceandconferencing/ata
Best regards,
Cindy Toy
Cisco Small Business
Community Manager
