benthach2000
Community Member
I just got SG200-26, is it possible to assign 10 static IP to say, port 2? If i can, please help with step? I greatly appreciated and big THANKS in advance.
jasbryan
Level 6
Level 6
No - you can't assign ip address to ports on an SG200 (switch). Normally when you assign ip address to ports, this is on a layer3 device/router.
Hope this helps,
Jasbryan
benthach2000
Community Member
Thanks Jasbryan for cleared this up for me. Can you point out a few device/router that can do this job? I would like to have the ones with web interface. also, it can be by cisco or other company. Again, I thank you.
jasbryan
Level 6
Level 6
Ben,
Can you explain to me what you are trying to accomplish so i could suggested the correct router/layer 3 device for you.
Jasbryan
benthach2000
Community Member
I'm trying to setup a dedicated server hosting. There is an GigE with /24 IPs coming into my switch/router, I"m trying to distribute these IPs to each server, each server would have 5 or 10 IPs ect. Thanks
jasbryan
Level 6
Level 6
So you're trying to dedicate a (5 or 10) range of public ip address to one server?
benthach2000
Community Member
Yes, that's correct.
jasbryan
Level 6
Level 6
Ben,
The small business line routers/switch isn’t going to allow what you need.
Yeah you will need to move up to the enterprise small business products
http://www.cisco.com/en/US/products/ps10906/Products_Sub_Category_Home.html
Enterprise pre-sales number
303-309-9852
You’re probably looking at ASA5505- Cisco800 series or even maybe 1900 series. Please look up spec’s and call the presales line for best choice.
ASA5500
http://www.cisco.com/en/US/partner/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
Cisco 800
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheets_list.html
Cisco 1900
http://www.cisco.com/en/US/products/ps10538/products_data_sheets_list.html
Hope this helps,
Jasbryan
benthach2000
Community Member
Thank you for all your help.
