LAG between Switch SG500-52P and SG550X-48 through wireless bridge
skylinksas
Hi everyone,
I'm certainly not an expert, I'd rather say a novice about the configuration of a switch.
Our network has grown and today we find ourselves having to connect 2 locations via a radio link.
What I'm trying to do is use 2 radio links to double the usable bandwidth between these two.
Since I don't want a connection with a backup, I think I understand that to force the use of both transmission channels I should NOT use the LACP protocol but, despite it seems a simple configuration, so far everything I've tried, reading posts and guides, does not seem to work.
In this moment I have enabled LACP to make the system work.
Both switches are updated with the latest firmware available.
At the moment I don't need to create VLANs.
The radio link (used for the LAG) could be the problem?
Is there anyone who has tried a similar application successfully?
If help, this the configuration of the ports
skylinksas
note: i have a 2.4GHz and a 5GHz bridge
