ping request timeout
LAMILIA
Visitor
hey every one
I am working on a sg300 switch that the interface VLAN 1 IP is 192.168.1.224 and the default gateway is 192.168.1.100.
the management IP of the switch is accessible from the ICT VLAN 15.
everything works ok but I have a virtual machine in VLAN 1 when I ping the sg300 from the virtual machine the ping on the VLAN 15 requests time out.
many thanks.
Deepak Kumar
Do you have inter-VLAN routing on between VLAN1 and VLAN15? Do you have any default route or static route for your VLAN 1 on the switch?
Check both and hope you will get an answer.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar,
