12-06-2016 08:51 AM
I just setup a new SG200-26FP and was having a problem with our polycom phones and noticed i still had Smartport enable, but when i try to disable it, it locks up and i cant login to it until i power cycle it.
1.4.5.02 |
1.3.5.06 |
Any idea or things to try?
Solved! Go to Solution.
12-10-2016 01:47 AM
yep, you're right, my mistake, sorry.
in that case:
12-08-2016 08:40 AM
I don't think that switch crashes. I would say that with disabling smartport feature you just get kicked from switch due to resetting switch port configuration (to default?). Reboot in your case helped because your configuration wasn't saved and it get restored (incl. reenabling smartport feature) after reboot.
The best would be to do it with using console connectivity.
12-09-2016 03:01 PM
When you say Console do you mean plugging into the back using a Seral cable? If so looks like SG200s do not have that.
Did a little more reading and saw this post on here
The SG200 has no CLI interface, so there's no way to enable telnet or SSH access.
I may just call cisco for support then..
Thanks!
12-10-2016 01:47 AM
in that case:
