WET610N bridged to WRVS4400N
nissentra97
I am have a lot of difficulty getting my WET610N to connect to my WRVS4400N.  I have tried almost everything.  I have some older PC's, as well as my PS3, that we use to use on the network and they only connect B/G.  I have tried auto DHCP and static IP on the bridge.  It seems that the only way that the bridge works is by using the WPS function that the business class routers do not have.  Any help is appreciated.
streaves
Hi Christopher -- Thanks for participating in the Cisco Small Business Support Community. Recommend you visit the Linksys site for support on your bridge. Here's a link to get you started: http://homesupport.cisco.com/en-us/wireless/lbc/WET610N/download.
Stephanie Reaves
