Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gear Support page index - Contains ...
CoreyP319 by Cisco Employee
  • 3843 Views
  • 1 replies
  • 5 Helpful votes
Got 79% through adding a 140AC. Told me to connect to my new SSID. I can access the Internet, as can others, however the app cannot add the 140. Removed and re-installed the app, and tried to create new site and discover the 140. 0 devices found.
cexc by Frequent Visitor
  • 281 Views
  • 2 replies
I have a new 140AC. It cycles through, gets to stage 8, the briefly hits stage 9 for about 5 seconds then cycles back to stage 8. And keeps doing this. https://www.cisco.com/c/en/us/td/docs/wireless/access_point/csbap/CBW_Admin/Admin/en_US/b_Cisco_AP...
  • 516 Views
  • 3 replies
Hi,I'm setting up a guest ACL on a Cisco 150ax for the Guest WLAN.As I simply wish this to be a second (Guest) WLAN to the primary business LAN (using WPA2/WPA3 credentials) I need to lock down access to other business devices etc and are looking to ...
QA-DK by Community Member
  • 807 Views
  • 3 replies
