2013-07-19 10:15 AM
通知情報に関するシビラティは以下の通りです。この情報は Portal 上でも
Personal Profile > Email Notification Preferences > Minimum Level の
“クエッションマーク”をクリックすることで確認ができます。
Basic Services | Severity | Alerts Summary |
New Devices | Informational | Information on new devices on the network. |
Missing Devices | Informational | Information on missing devices on the network. |
Proactive Notifications | Severity | Alerts Summary |
Security Alert | Critical Important Informational | Critical security issue. Important security issue. Information on a security issue. |
End of Support | Critical Important Informational | End of hardware support and software support within 90 days. End of hardware support and software support in more than 90 days and less than 1 year. End of hardware support and software support in more than 1 year and less than 2 years or End of sales within 30 days. |
Field Notices | Important | All Field Notices. |
Core Technology | Severity | Alerts Summary |
Assessment | Critical | The Core Assessment service has not been run in more than 30 days. |
Device Availability | Critical Important | Core device availability is less than 99.0%. Core device availability is between 99.0% and 99.90%. |
Core Backup | Critical Important | Core backup has not been done in more than 3 months. Core backup has not been done in 1 to 3 months. |
CPU Utilization | Critical Important | CPU used more than 75%. CPU used between 75% to 50%. |
Security Technology | Severity | Alerts Summary |
Assessment | Critical | The Security Assessment service has not been run in more than 30 days. |
Device Status | Critical Important | The Security Syslog Report indicates that the severity level is less than 3. The Security Syslog Report indicates that the severity level is equal to 3. |
Voice Technology | Severity | Alerts Summary |
Assessment | Critical | The Voice Assessment service has not been run in more than 30 days. |
Device Status | Critical Important | The Voice Syslog Report indicates that the severity level is less than 3. The Voice Syslog Report indicates that the severity level is less than 3. |
2016-08-15 05:42 PM
"Security Assessment"と"Core Assessment"がクリティカルになっています。
こちらはAssessment serviceが30日以上未実行を意味しているそうですが、実行されなかった原因を調査する方法はありますか?
また、この状態を解消する方法はありますか?
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
