DNAC Installation Stuck at “Wait for Kubernetes Control plane to start
zmtechnologie
Hello everyone,
I'm encountering an issue during the installation of Cisco DNA Center on my server. Although all the necessary system requirements (CPU, RAM, storage, etc.) are met, the installation process gets stuck at the following step:
FAILED - RETRYING: Wait for Kubernetes Control plane to start functioning (1 retries left).
fatal: [localhost]: FAILED! => {"attempts": 300, "changed": true, "cmd": "kubectl get nodes --kubeconfig \"/home/maglev/.kube/config\""}
gernotstoiser
I have tha same issue. Tried OVA with 2.3.7.6 and 2.3.7.5 in our lab env. Always ends up the same error. Did you fix this issue?
2.3.7.7 worked ok for me. 2.3.7.5 ended up with the same error you had.
julian.bendix
Level 7
Level 7
Which version? 2.3.7.9?
Virtual or Appliance?
balaji.bandi
As long as the all the resources are correct it take some time and also you have internet connectivity working.
I did some installation all went as expected virtual and Physical appliance.
Note : check some important notes in the blog.
https://www.balajibandi.com/?p=2515
BB
