5010 in fcoe-npv
tpahuja
Folks,
           When I enable fcoe-npv feature on my 5010, I notice that it does not recognise fc ports on my expansion slot.
2    8      4x10GE + 4x1/2/4G FC Module      N5K-M1404              ok
when I enable fcoe and npv individually then it recognises the FC modules. Is the behavious the same on 5548s?
Any help would be highly appreciated.
Daniel Laden
Level 4
Level 4
This is probably expected behavior.  The FCoE-NPV license is only for FCoE.  The would not include FC ports.
Enabling FCoE NPV
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/san_switching/503_n2_1/Cisco_n5k_nxos_sanswitching_config_guide_rel503_n2_1_chapter6.html#task_3173F5B59F604137A1F9C2775A24747C
You can enable FCoE NPV using the feature fcoe-npv  command. We recommend this method in topologies that include all FCoE  connections. A write erase reload does not occur when you use this  method and a storage service license is not required. Enabling FCoE NPV  using the feature fcoe-npv command requires an installed FCOE_NPV_PKG  license.
Thank You,
Dan Laden
Cisco PDI Data Center
Want to know more about how PDI can assist you?
http://www.youtube.com/watch?v=4BebSCuxcQU&list=PL88EB353557455BD7
http://www.cisco.com/go/pdihelpdesk
