05-24-2018 12:49 PM - edited 03-01-2019 06:19 AM
We have a 5548UP and am having problems with some new FET 10G we just got.
I get the error message N5548-A %ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transc
eiver on interface Ethernet1/7 is not supported
when I do a show int transceiver it looks ok
Ethernet1/7
transceiver is present
type is Fabric Extender Transceiver
name is CISCO-LUMENTUM
part number is PLRXPL-VC-S43-CG
revision is C
serial number is JUR2049B1VW
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM3 fiber is 100 m
Link length supported for 62.5/125um fiber is 10 m
cisco id is --
cisco extended id number is 4
We have other FET 10Gs that work but they seem to be a different model
Ethernet1/5
name is CISCO-FINISAR
part number is FTLX8570D3BCL-C1
revision is A
serial number is FNS15401XH4
cisco id is --
Any idea why the newer FET 10Gs are not working
description Uplink to Nexus2248-2/1
switchport mode fex-fabric
switchport trunk allowed vlan 10,20,30,60,1402-1404,1420
fex associate 102
duplex full
channel-group 102
interface port-channel102
description Uplink to Nexus2248-102
fex associate 102
duplex full
vpc 102
05-24-2018 12:56 PM
More information
We are connecting the 5548UP to a 2242 and to a 2232 FEX.
05-25-2018 05:41 AM - edited 05-25-2018 06:20 AM
What N5K version are you running?
Different firmware versions may detect newer SFP transceivers differently.
Some 5600s in the lab show that SPF name as "CISCO-JDSU"
Kirk..
05-25-2018 05:58 AM
System version: 5.2(1)N1(7)
05-25-2018 06:10 AM
Sent you a PM.
Kirk...
