Adding new MDS switches into exisitng VSAN in NDFC
TimDo
Hi there everyone,  I'm reaching to see if anyone knows how to add new MDS switches into an exisiting VSAN in Nexus Dashboard Fabric Controller (NDFC version 12.2.1.316).  This option was available in Data Centre Network Manager (DCNM) by going to DataCentre-->SAN.  Right mouse click on the VSAN that you want to add the new switch and then select "Add Switches to VSAN.
Tim
Tarakesh Jetti
You can follow this deployment guide.
https://www.cisco.com/c/en/us/td/docs/dcn/ndfc/1221/articles/ndfc-add-switches-lan/add-switches-for-lan-operational-mode.html
if you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco Nexus Dashboard Fabric Controller (NDFC, previously known as DCNM) through our live Ask the Experts (ATXs) session. Check out this ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Let me know if you have question / issue.
Thanks and regards,
TJ
Customer Success Specialist
Thanks for the info but this document relates for NDFC for LAN and not for SAN which is what I'm after.
Go into manage/fabrics; open the fabric that the switch is being added to and go to the VSAN tab. Once there you can add or manage any VSANs needed.
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
Thanks and regards,
TJ
