Need help with Nexus 3000 Password Recovery
gchevalley
Anyone know how to reset the password on a Nexus 3000?  I have tried the procedures for the Nexus 5000 with no luck.
richbarb
Did you follow this procedure? far as I know works with all nexus plataforms.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/password_recovery/nx_os_pw.html
Richard
7 Replies 7
richbarb
Richard
Here is a video with the MDS.
https://supportforums.cisco.com/community/netpro/data-center/storage-network?view=video
Sometimes Ctrl-] does not work with the emulator, so you can use Ctrl-C, then run the kickstart.
David
I followed the procedure but it looks like we did not wait long enough into the boot sequence.  From past experience I am used to getting into ROMMON early on when the device begins to load.  It seems on the Nexus that it is further along in the boot sequence, after POST, that your able to break into ROMMON.  The maintenance window we had has closed so I'm waiting for the powers that be to schedule another outage.
Thanks guys, finally able to get the password recovered.
eosterberg
I am having a hell of a time finding the right moment to press <CTL>-]
Here's an example. Can someone help me understand at what exact moment I press the key sequence?  This is a new switch for me, yesterday I removed it from the box and entered the initial configuration dialog. I set my password ( I'm using: a5I*Wf+R*mq\At"|  ) maybe that combination of characters is a part of the problem?  PS: I will of course use a different password now!
GRUB Loading stage2
[    0.000000] Fastboot Memory at 0c100000 of size 2013265922.U2.2.bin....
ÿUsage: init 0123POST INIT Starts at Tue Sep  9 16:51:24 UTC 2014
Starting Nexus 3000 Platform POST.....
  Executing Mod 1 1 SEEPROM Test:...done (0 seconds)
  Executing Mod 1 1 GigE Port Test:.done (8 seconds)
  Executing Mod 1 1 PCIE Test:.................done (0 seconds)
  Mod 1 1 Post Completed Successfully
POST is completed
.... done.
Loading System Software Tue Sep 9 16:51:43 UTC 2014
^] <---( I pressed ctl-] right at this moment )
System Software(/bootflash/n3000-uk9.6.0.2.U2.2.bin) Loaded Tue Sep 9 16:52:00 U
TC 2014
ethernet switching mode
INIT: Entering runlevel: 3
Mounting other filesystems:  [  OK  ]
Set name-type for VLAN subsystem. Should be visible in /proc/net/vlan/config
Added VLAN with VID == 4042 to IF -:muxif:-
2014 Sep  9 16:52:07 BLM-80-A-2-41-CoreSwitch %$ VDC-1 %$ %USER-0-SYSTEM_MSG: FA
ST REBOOT DISABLED - bcm_usd
2014 Sep  9 16:52:07 BLM-80-A-2-41-CoreSwitch %$ VDC-1 %$ %USER-2-SYSTEM_MSG: CL
IS: loading cmd files begin  - clis
2014 Sep  9 16:52:19 BLM-80-A-2-41-CoreSwitch %$ VDC-1 %$ %USER-2-SYSTEM_MSG: CL
IS: loading cmd files end  - clis
IS: init begin  - clis
2014 Sep  9 16:52:49 BLM-80-A-2-41-CoreSwitch %$ VDC-1 %$ %USER-0-SYSTEM_MSG: St
arting bcm_attach - bcm_usd
2014 Sep  9 16:53:04 BLM-80-A-2-41-CoreSwitch %$ VDC-1 %$ %USER-0-SYSTEM_MSG: Fi
nished bcm_attach... - bcm_usd
2014 Sep  9 16:53:18 BLM-80-A-2-41-CoreSwitch %$ VDC-1 %$ %VDC_MGR-2-VDC_ONLINE:
 vdc 1 has come online
User Access Verification
BLM-80-A-2-41-CoreSwitch login:
Ok, problem solved on a 3064 switch. I used aggressive ctl-C before the GRUB prompt and I moved from a minicom based network terminal to a direct attach laptop at the same console port. Then it was just following the instructions already mentioned.
MJ666
@gchevalley  did you had access to the CLI(ssh or loacaladmin)  ?
