Call Home not working after upgrade.
User_4444_2
After we upgraded from 3.3(1c) to 5.2(2) our Call Home has stopped sending emails when any host logs out/into any of the switches. Nothing else has changed, the same profles exist with the same “MsgLevel” settings.
In the release notes for 4.2(1b) it states; “In MDS NX-OS Release 4.2(1b), CFS cannot distribute the following Call Home commands that can be
configured with the destination-profile command:
                    • destination-profile profile_name transport-method
                    • destination-profile profile_name http”
That does not show up when we run “sh running-config callhome”.
We can still run a Test or Inventory without any issues and we receive the emails.
The interface with logging level 5 is probably a port-channel.
You can look at the raw output of the command to be sure.
Since you can't | to (5), you can capture the output to a file, then search the text file.
David.
6 Replies 6
dakester
The upgrade got you a new knob to change the syslog level for link failures.
For syslogPortGrup to callhome the syslog level needs to be critical.
Is this what you are looking for?
config
logging level port link-failure crit
My callhome test worked with this config.
callhome
  email-contact sysadmin@cisco.com.com
  phone-contact +1-800-555-5555
  streetaddress 123 Main Street, USA
  destination-profile full_txt email-addr test@cisco.com
  destination-profile short_txt email-addr test@cisco.com
  destination-profile xml email-addr test@cisco.com
  no destination-profile full_txt alert-group all
  destination-profile full_txt alert-group RMON
  no destination-profile short_txt alert-group all
  destination-profile short_txt alert-group RMON
  destination-profile full_txt alert-group test
  destination-profile short_txt alert-group test
  no destination-profile xml alert-group all
  transport email from switchname@db.com
  transport email reply-to no-reply@db.com
  transport email smtp-server a.b.c.d port 25
  enable
exit
David
Did the change but when I run "sh logg level port" afterwards it was the same as before? Still at 5 (Notifi).
Facility        Default Severity        Current Session Severity
port                    5                       5
0(emergencies)          1(alerts)       2(critical)
3(errors)               4(warnings)     5(notifications)
6(information)          7(debugging)
HI,
Thanks for the feedback.
I need to research or open a new bug for 'port link-failure' not listed in the output of 'show logging level'.
Check the output of ...
9513-2(config)# show port internal info all | i syslog
Global link failure syslog level = 2   <------ global level
    Link failure syslog level (5)     <----- interface level
The workaround for ....
CSCti92353    IF_DOWN_LINK_FAILURE_CRIT not generated
... is ..
After upgrading to a release with the fix you will need to reconfigure the link-failure logging level to activate the fix.
   Config
   no logging level port link-failure crit
9513-2(config)# no logging level port link-fail crit
From my lab switch...
9513-2(config)# logging level port link-fail crit
    Link failure syslog level (2)
David
Strange, all of them say 2 except for one of them three from the bottom? I will wait for the email to arrive.
David.
That did fix the problem but the emails are much bigger than before, shows lots of the last logouts/logins. Might be "show logging logfile | tail -n 200" that shows up in the email.
