08-31-2022 08:50 AM
09-07-2022 10:27 AM
yes you can do as many as alias in hostfile (its does not matter) - if you do not like to change the hostname of the switch,
hope that helps you.
08-31-2022 09:00 AM
not sure we understand the question, can please explain bit more ?
08-31-2022 09:04 AM
Instead or renaming the hostname of the switch. We're looking to give it alias. Hopefully that response was better.
08-31-2022 09:25 AM
Instead of updating PROD Catalyst C9300 hostname ACBDEF. Is doing a alias hostname 123456 possible?
08-31-2022 09:46 AM
how are you resolving ABCDEF ? via DNS, then add one more DNS Entry against IP
make DNS Entry what ever you like, changing hostname not cause any network outage for your informatiin.
09-07-2022 07:25 AM
Unfortunately, we're not using DNS.
09-07-2022 08:14 AM
how do you expect resolution take place (until you going to tell me changing host files ?)
09-07-2022 08:58 AM
Instead or renaming the hostname of the switch. We're looking into Changing the Host file(alias) as an option. Hopefully I written that correctly
09-07-2022 10:27 AM
